Alb
Moderator
- May 11, 2021
- Solutions
- 6
- Gloucestershire driving an MGS5 LR Trophy
Mine's just over 4 years old and no rust.
Really?, not even under the bonnet around the pressed holes? They all go rusty there!Mine's just over 4 years old and no rust.
I agree, It really is terrible!My reply was given in the context of this specific thread.
The corrosion in those photographs is unusual in the extreme.
I'm sorry, but what you just posted is total and utter nonsense. Sounds like an April 1st joke!It's been known for some manufacturers to use steel that has not been 'weathered'. As some will know this process involves stacking sheets of steel used in the production of cars out in the weather, unprotected from rain etc. Some manufacturers even spray the new steel with salt water to speed up the corrosion of the steel. This is carried out to allow natural processes of oxidisation to 'corrode out' the imperfections in the surface of the steel sheets. Without this being done the imperfections can start the oxidisation process under the surface of the painted metal. Car makers are sometimes tempted to do this when weathered steel become in short supply & to save closing down a production line they grab some unweathered steel to use instead.
My car is a new ZS EV & I've just coated it underneath with Waxoyl & Bilt Hamber box section wax. Hoping it won't rust. I haven't seen any rusty ZS's so far underneath & I've seen a few up to 5 yes old. No rust. Not seen any MG5's either.
Sheet steel for car production is kept dry and clean, there is no such thing as "weathered" sheet steel, if you knew anything about metallurgy you'd understand why what you posted is utter rubbish. If sheet steel is ever allowed to start rusting prior to painting, it will never stop, and the paint will fail.
In any case, most sheet steel is now zinc galvanised when used in car production, for longevity and this process only works on perfectly clean steel.
From my body in white automotive adhesive bonding days I can confirm everything is galvanised but also covered in oil not dry.I'm sorry, but what you just posted is total and utter nonsense. Sounds like an April 1st joke!
Thanks Paulie for pointing that out but you clearly haven't been present at a car factory when sheet steel is being delivered. And it certainly isn't an April fools type joke. When I've seen this the steel was already quite rusty. Albeit this was a few years ago & sure processes may have changed I fully accept that. I'm now retired. It may be the process isn't popular at the factories now, it's been a while since I was involved at that end of the business, but generally the steel is still weathered if needed before galvanisation as it will still contain impurities. It may be artificially weathered more quickly these days but it's still weathered. We are NOT talking about CORTEN STEEL type weathering. That's not required. We only wanted the early corrosion that takes place. Yes I know you can get differing grades of steel with differing levels of impurities or purity. But some of those can be very expensive. I've seen our sheet steel covered in rust after initial weathering then dipped in an acid bath & coming out completely clean & shiny without those surface imperfection at the other end. Under the microscope there is no trace of oxidisation. Trust me, I've seen it, It's then galvanised or processed in whatever manner is required. I suspect some of this is carried out at the steel factories now but car bodies once built still undergo various electrostatic & electrophoretic treatments after acid baths. I'm sure these processes have been refined also over the years.I'm sorry, but what you just posted is total and utter nonsense. Sounds like an April 1st joke!
Back in the 70's British Leyland, due to their stupidity, let steel sheet get wet, whilst waiting for it to be processed in the pressing shops, leading to rusting. Some bodies in white were also transported in the rain between factory buildings. This was not part of the planned process, but incompetence and as a result some of their cars suffered from appalling premature corrosion.Thanks Paulie for pointing that out but you clearly haven't been present at a car factory when sheet steel is being delivered. And it certainly isn't an April fools type joke. When I've seen this the steel was already quite rusty. Albeit this was a few years ago & sure processes may have changed I fully accept that. I'm now retired. It may be the process isn't popular at the factories now, it's been a while since I was involved at that end of the business, but generally the steel is still weathered if needed before galvanisation as it will still contain impurities. It may be artificially weathered more quickly these days but it's still weathered. We are NOT talking about CORTEN STEEL type weathering. That's not required. We only wanted the early corrosion that takes place. Yes I know you can get differing grades of steel with differing levels of impurities or purity. But some of those can be very expensive. I've seen our sheet steel covered in rust after initial weathering then dipped in an acid bath & coming out completely clean & shiny without those surface imperfection at the other end. Under the microscope there is no trace of oxidisation. Trust me, I've seen it, It's then galvanised or processed in whatever manner is required. I suspect some of this is carried out at the steel factories now but car bodies once built still undergo various electrostatic & electrophoretic treatments after acid baths. I'm sure these processes have been refined also over the years.
I do still see new cars rusting underneath along seams that have no sealant or other protection over them. Not so much MG's yet but I've seen many other makes rusting after just 2 or 3 years. Even Honda's & those used to be pretty good. My Citroen was 7 years old with no rust whatsoever because I gave the car a good soaking in Waxoyl & Bilt Hamber when it was new. I think this is a good idea when you get your new car or if it's two or three years old. It should considerable lengthen the cars life.
I came into the motor industry when there was no galvanised metals or any other fancy processes to prevent rust. Weathering of the type above was widely used for SOME parts of the car at the factories. I'm pretty sure there was a video showing this short term weathering as they called it, by VW. This was some years ago on some tv documentary. I do wonder if it's still used in the far eastern factories!
Just to give an update on the attached corrosion issue
MG said they were not accepting responsibility for the rust issue but were offering £800 towards repair costs. Work that one out !!
This steel is used In shipping containers and they have a label on them saying only use Cor Ten steel for repairsThat said, CorTen is a 'weathering' steel (though never used in mass-produced cars to my knowledge) used for stuff that wasn't/isn't ever going to be painted.
