iSMART app v1.1.2 available
Oooh, sounds good, what was updated exactly, the infotainment system ?
Mine went back in to adjust the washer jets and was told it needed an update, I asked what was updated and was told BCM, EVCC and FCR … whatever they are… I did notice that my infotainment was now at R33 , updated from R30, and that the energy consumption graph now worked.
How efficient! :D
The phones are so darn clever it even has an option to automatically install updates when they’re available…although that’s a tad too much control for me to hand over…
Thanks, that is likely it then, I have it plugged in, in the garage.
So in effect, an idiotic bug ? as you cannot control the AC if the car is hooked up. So I could not initiate a cool-down, or heat up, of the interior because it's plugged in !
Yep, unfortunately.
Discussed here:-
I updated the iSmart app on my iPhone.
The update has not fixed the Bluetooth Key (I can still only enter the car but cannot start it).
More seriously the lock/unlock feature via the app is dodgy. I opened the car using the app (did not need a PIN code). Likewise I closed the car with the app. I checked that the mirrors folded which is my confirmation that the car is indeed locked. However a bit later I looked at iSmart and it told me my car was unlocked!
I’ll try to replicate this to see if it was a one off or a continuing problem.
I had given "Location" permission but it still showed Berlin. However after closing the app and opening again it now shows correctly. :)
Result
The good old, turn it off and back on again. Now where have i seem that before?
I have noticed with the latest update (Android, 1.1.11) that whilst discharging using V2L, you can't lock the car using the app but still can ok using the key fob or door button.
    Votes: 1,023 77.9%
    Votes: 195 14.8%
    Votes: 96 7.3%
