Keeping track of my MG4 (efficiency)
Someone was feeling optimistic yesterday! I even turned on ECO mode, just for those magic extra km. :D
This is the result of a trip I did during the past weekend, which consisted of 253 km, on something equivalent to A- and B-roads.
It was hot (around 27ºC), there were 3 of us inside the car and the AC was on the whole time, on 22ºC.
The average speed was 64 km/h (~40 mph) and the consumption 12.2 kWh/100km (5.1 mi/kWh), which is frankly good and the reason why the GOM was feeling so optimistic.
The car was still showing 36% of battery remaining (141 km) at the end of the trip.
That's pretty good! I was able to hit 123Wh/km the other day. 95% highway driving at 95km/h and this was roundtrip (one way i was able to get 114Wh/km).
Next i'm going to test with summer tires (currently running winters with petty high rolling resistance) and with more pressure (this test was around 2.5bar).
I'm keen to see how low can you go. I think i still have atleast 5-10% more efficiency on the table, so 110Wh/km roundtrip shouldn't be too hard to hit in good conditions. With 51kWh gross and 47kWh usable (a bit of degradation and some bottom buffer i suspect) i think over 400km is achievable on highways using slow lane and have some buffer left over.
Your figure is even more impressive, considering it was at 95 km/h.
The best I've accomplished so far was:
  • 11.4 kWh/100km on a 90 km roundtrip (averaging 50 km/h);
  • 10.0 kWh/100km on a 26 km roundtrip around the city (33 km/h).
Given my location, I'm always on summer tyres and I currently have my tyre pressure set to a value which makes it change on the display from 2.5 to 3.0, depending on how cold/hot it is (we've been having high temperature fluctuations).
As for the best possible results, I'd say Bjørn Nyland's test is a good benchmark on that. Images below were taken from one of his videos:
Yeah, i think it was pretty good result also. Do note that it was around ~22-23C (although i had AC blasting the whole time). And i'm running 16s (205/60R16) so that might help me a bit as well. And of course this was behind a truck most of the time, so i had some aero advantage as well.
Im considering buying either e.primacy or e.ziex tires as both have excellent rolling resistance.
First post updated, with April's data:
PeriodDistance (km)Efficiency (kWh/100km)Average Speed (km/h)Up Time
April 2025111014.7 (4.23 mi/kWh)3432:14
Current overall combined efficiency: 15.1 kWh/100km (4.11 mi/kWh)
I was updating my Excel sheet today and realised I had not been tracking the difference between what a charger records as energy sent to the car and how much energy the car records as being stored in the battery (based on % charge). Have updated this and can see a 220kW discrepancy since I have owned the car, of which only 106kW was paid for and at about 8p per kWh that is a loss of about £8.40. Also impacts the efficiency stats which are closer to 3 miles/kWh using the battery figures not the charger figures.
Yes, all my numbers are based on the energy I "pay" for be it DC fast chargers, home charging, destination charging etc.
So my long term average of 17.55 kWh/100km is the energy supplied, not the DC drive energy consumption which would be something less than that.
May was a quiet month for driving, weather was atrocious, massive flooding throughout the region.
Ended the month with a trip to Sydney to collect our second EV, this one for my wife. A 2022 ZS EV Excite with less than 10 km on the odo. So I guess that adds 526 km to the month's numbers, just in a different car.
First post updated, with May's data:
May 2025147814.3 (4.35 mi/kWh)3146:24
Current overall combined efficiency: 15.1 kWh/100km (4.13 mi/kWh)
This also marks pretty much one full year with the car (I picked it up on June 7), with close to 17,000km on the odometer and zero major issues. I really love it.
My only complains would be:
  • A rattling noise coming from the front screen, whenever I'm going on roads with a bit more degradation (and when the weather is hotter). I hope to sort this soon, in the first service;
  • Two or three cases of aggressive phantom braking. It is what it is (and not restricted to this car), but having an option for simply turning a custom profile on (like on the MG 5S) would be most welcome at some point;
  • A very high increase in consumption when turning the heating on. Again, it's a common reality in the EV world, but still I find it to be more accentuated on this particular model.
Models in some markets are fitted with heat pumps for heating. Australian models are not and so rely on resistive heating elements which would consume several times the energy for the same heat output. Perhaps yours is the same.
Yes, that's definitely the case.
While here in Portugal heat pumps are fitted in the upper models, the Standard 51 kWh (which is mine) does not. And I am aware of this.
But even so, based on my experience from other EVs I've owned and tried, I really think the consumption when heating the cabin is out of the ordinary in this car.
First post updated, with June's data:
June 2025247614.3 (4.35 mi/kWh)4160:49
Current overall combined efficiency: 15.0 kWh/100km (4.15 mi/kWh)
This was, by far, the month in which I drove the most since I've had the car. Did a couple of long-ish journeys, of around 275 km each, all of them in a single charge.
Other than that, the car had its first service in June, from which I can add a couple of notes:
  • While I was told (when I dropped the car) that a software update was on the "to-do" list for the car, the truth is that when I picked it up it was still on R33. I'm OK with R33 (and, secretly, I don't want to lose the drop-down option while on AA); just found this strange;
  • I mentioned the rattling noise (coming from the front screen) to them, but they simply didn't care. They simply said they couldn't hear anything, although I know they did not even drive the car... I'll need to book an appointment with them specifically for this if I want to see it fixed.
  • I am very happy that now I don't get bad smells inside the cabin when having the ventilation turned on with the air coming from the outside. I used to only be able to drive with recirculated air because I would immediately be faced with the awful smell of burnt diesel inside the cabin. I'm guessing they changed the cabin air filter and it is night and day difference.
That explains it. I'm using a dark background.
Still, not sure how I did that. :rolleyes:
Edit:
I'll look into it tomorrow. Thanks for letting me know.
Oh my.
I'm now on my desktop, using the Light Theme, and discovered I've been using this odd colour font ever since February!
I'm very sorry about it, but it went completely unnoticed on a Dark Theme.
I've now edited all previous posts (I think I did not miss any).
Thank you again and let me know straight away if something like this ever happens again.
    Votes: 1,084 77.8%
    Votes: 208 14.9%
    Votes: 103 7.4%
