MG IM6 information & reviews
Status
The first post in this thread is a WikiPost, and can be edited by anyone with the appropriate permissions.
New video up and down the mountain, he has done this drive with a few cars when he is in Thailand.
He mentions MG capping the consumption at 2.98 watt hour p/km a few times even though it is worse, loves the rear wheel steering on the 6
Regarding grip levels, the Pirelli Scorpions he was talking about are road touring tyres with some offroad capability. Not sure if car variant is that much different, but on the motorcycle, they have wide angular threads to provide grip on rough road with bigger and loose aggregate. This meant the contact patch is less compared to a dedicated road tyre. I believe UK ones have P Zeros. Owners please correct if i am wrong.
These EVs are crying out for an LSD. The TC kicks in at beds which suggest differential wheel spin. Alfa Romeo fitted a rather basic Torsen type (helical) LSD for their FWD Junior EV and transformed the car into a track demon from its Jeep underpinnings. But the IMs are heavy enough.
We are on the cusp of an exciting time in EVs. With solid states finally becoming a reality, we can see performance models that can now use trick parts like LSDs and possibly even an overdrive gear to boost top speed and performance.
Hi all! I'm considering putting an order in for an IM6, possibly with the grey exterior, but I'm a little torn about the interior. I really like the look of the white/beige, but I have two kids (aged 11 and 8) and am worried that the lighter colour may mark over time.
One review I saw on You Tube said the white interior in his test vehicle was already started to show discolourations after only (presumably) light use.
Have any of you who have the white interior had any issues with it? Would you recommend it or not?
In general, if you have kids, avoid white/beige.
Good point, the tyres may well be different here.
A LSD would be inappropriate: these vehicles are aimed at quiet comfort, not track work (excluded by warranty anyway).
Yep. I'm sure you're right. Shame though, as on video at least, the beige does look a little more upmarket to me. Damn! 😅
I agree. I'd be interested in white/beige (no kids), although I did have a white interior in a Jag years ago and I found jeans turned it blue, which was an issue.
I would say the white/beige makes it look more roomier and bright and gives it that premium look. I have a now 12 year old and happy to have the light interior as should be easy to clean, plus not only kids to worry about getting it messy but also shopping, bikes, scooters etc too but still prefer the light interior. Also if it helps the light interior is a combination of dark and light which makes it standout.
A helical type (torsen) is not sounding at all, and will not cause bad wheel hop and so on, like the clutch type LSDs. On a track clutch plates would be the best thing, for road use torsen is good if the car has EBD as ASR. On the rear of the IM6 performance it would be a good addition I think, no bad comfort effects, just better traction.
I was just about to reply to the same effect. I actually think an LSD, well-tuned, combined with traction control, EBD and ABS are excellent safety aids, especially for high torque RWD vehicles.
All modern vehicles have an e-LSD function to control differential wheel slip these days by applying brakes to the wheel that's lost traction, followed by retarding engine power if the slip continues. While it stops the car from going into a spin, it does slow it down.
I had my Giulia with LSD and semiactive suspension before my current AWD Stelvio. The traction control never kicked in. The LSD alone kept the car under control when the wheel slips. No I wasn't raing. Case in point, just the day after putting that post, the LSD in my Stelvio was called into action.
It was one of the frosty mornings last week and I was pulling out of junction, turning right just outside my residence. So the roads were icy and my tires to as I had just started driving. A car was approaching left but there was enough time and space for me to pulled out. So gave it a little beans to not be a nuisance. The rear started slipping as I turned right and my nose pointed towards the opposing lane (it was a quiet residential road and it was completely clear on this side when i made the manouvre). No drama, feathered throttle little and counter steered, the car continued to move forward and slid smoothly and controllably sideways onto the correct side. All done in a few seconds. What mattered was the LSD (and probably some AWD) allowed the wheels to continue driving to move the car away from approaching traffic while remaining steerable and under control.
One common story of RWD cars is getting stuck pulling out of busy junctions as the wheel slip led to the TC cutting off drive to the wheels.
I don't know how much this would apply to the AWD variants of the IM6. I will post my experience when I get my car!
Had a white interior in my Ioniq 5 and after 4 years it was still near perfect. Only ever used a damp cloth on it. No children but a damp and muddy dog….
It is heavy enough already. Overkill.
That I agree. the weight penalties outweight the performance benefits. It will have to be a stong LSD as well given the huge torque. So just to digress a bit, that's why I think solid state batteries will be a game changer by bringing the weight right down to ICE levels.
When I installed a clutch and plate type LSD in my previous racecar, I took out the original open diff. I don't think there was any weight difference between the two. Maybe a torsen will weigh a bit more, maybe 1 kg?
When I tested the IM6 several months ago, with summer tires, there were traction issues even if it was the AWD version. Clearly felt the anti spin shifting the power left/right several times in a full pull. With a torsen it would have felt more stable (with the traction control still on), but would have accelerated quicker. It has enough power to utilize a LSD of this type.
I am not saying it wouldn't be better with a LSD. And ok, maybe it wouldn't be heavier.
But the whole point of MGs/IMs is to provide better value than the competition and they do that by leaving out things that otherwise would make it more expensive.
This isn't something I'd expect to feature on a very large and heavy comfort-oriented SUV. As such, I think it is overkill and I suspect we could get a list from people of 10 things that they would like to have on the car which would raise the price significantly.
There are always ways of making a car better. The trick is to get the price/performance balance right for the market. I think they've done that well.
Arguably the Performance variant is overpowered for what it needs, that's fair comment.
I think it's a case of IM and the Chinese trying to find their niche. I disagree it just a big and comfy car. They and BYD were both playing up the bhp game and 0-60 times. So there is an element of performance and sportiness they are trying to market. Furthermore, the IM5/6 weren't just marketed by MG in Europe because of dealer networks. The non-active suspension has actually been tuned by the MG testing team at Longbridge to provide a more sporty and responsive ride (with mixed results). So they do seem to try to pitch the IMs as sporty tourers in the European market. And it makes marketing sense. Sports variants are marquee models to drive media attention, brand awareness and sales of cheaper variants.
But the Chinese despite their advanced tech, are still in the stone age when in comes to marketing. The best example was when BYD sponsored the last Euro tournament and had some completely garbage assigned URL for their german website. Most German viewers thought it would be byd.de ( I mean of course, right?). Turned out to be a dildo company!
Going back to LSD, I had a quick look. Both the Xiaomi SU7 and Yanwang U9, the EV supercars of China do not have LSDs. They have individual motors driving each rear wheel and vector torque accordingly. Which makes sense as it provides better control, easier finetuning and mechanical simplicty. but certainly overkill for a mass market model. However the differentials of EVs are built into their motors unlike ICEs, especially rear driven ones. This makes changing them impossible.
But the Alfa Romeo Junior has a simple Torsen LSD fitted and it is credited in lifting the car to greater heights. Simply because the huge EV torque is better distributed and utilised without any need to reduce drive power to regain traction.
And it is not true sportiness has to be sacrificed for comfort. Maserati for example is marketed as a sports GT. vs Ferrari which emphasises more on the sport bit.
So let's see. As I mentioned in a previous post, the Chinese reached higher income levels in the last decade or so. Cars were initially functional, then status symbols, but not toys. But there clearly is a demand now with the oversubscription of the Su7 and U9. So I don't think it will be long before sports tourers start appearing on the horizon. We will look back at the IM6 as an early foray into this sector.
Status
