Rabmc
Anyone else got badly scored rear discs? My 2019 ZS EV discs are very badly scored, I think it's the hand brake pressure that's caused it. I took it to the dealer and showed him the worn rear discs and said I reckoned it was an mot failure. He did not disagree but said MG would not change the discs under warranty after the car was over 12 months old. The car has done 12000 miles. So much for the 7 year warranty!!!I wouldn’t worry too much as all discs gets scored. As long as they are not badly scored, worn or corroded. The effective area that the brake pads operate on is not really impacted by light scoring. the odd stone will always get stuck in there and score the disc. The worst enemy on EV’s is lack of use and seizing/rust. It is worth now and then giving the brakes a bit of a work out if your normal driving means that they get very light usage. Nothing too severe. As i previously mentioned it is also worth popping the brake pads out every couple of years and having a general clean up and regrease, depending on use and road conditions.
Both rear discs are the same.
