MG ZS EV "Naked/Normal" Roof without Factory Rails- Rails FOUND - Summit SUP-055
christhirteen13
UK, Blackburn
MG ZS EV owners rejoice!!! I have found the perfectly fitting MG ZS EV roof rails for MGs without any exiting rails. They are relatively affordable. The following rails will work and best of all they are available on Amazon!!
-> Summit SUP-055 Premium Multi Fit Roof Bars, Black Steel, Set of 2
I have made following observations before ordering and installing the rails.
  • The width of the roof is approximately 127 cm, therefore the roof bar has to be at least 130 cm wide.
  • The edge where the mounts wedge into are the right type for the installation.
I have gone ahead and spaced out the bars with the following measurements.
  • The two bars are 70 cm apart from each other, apparently the optimal distance for such installations.
  • The rear bars are 47 cm away from the front doors rubber seal.
  • Front bars are set to 105 cm measured on the bar indicators.
  • Rear bars are set to 103.5 cm measured on the bar indicators.
Some issues with the product to be aware of.
  • Very loud wind howling noises at motorway level speeds, see more in test report further down.
  • The bars need to be widened, especially at the front (width 105 cm), the end caps of the bar tend to come off and aren't glued in properly. I had to cut the plastic and apply strong glue to the ends of them and fit them back on so they stay on.
  • Missing T-bolt groove for roof boxes or bike rails, need to replace roof bar with Thule one to sort this, also probably more aerodynamic at high speeds.
  • The caps that close off and conceal the adjusting screws are flimsy and cheap, it is possible that they will not last, neither will the screw to lock them as the thread is plastic too and weak so likely break and lose shape. I will potentially investigate buying Summit specific metal locks for this.
A test drive will follow I have literally just installed them today and I'll follow up with how they perform. Especially noise wise!
I might also test Thule Evo roof rails in the future using a kit that is compatible with the Hyundai i10 as that is a relatively new EV model that is on the list of supported cars for this Summit roof rail kit. Hence, a kit for that car should in theory work. Good news with Thule is that each kit 'only' costs about 50£ so swapping that in case of misalignment should be alright.
We did some tests!!!
Unfortunately, while the noise was just about tolerable at 50 MPH (80 KMH), once we hit 70 MPH (110 KMH) it went full “angry banshee mode.” Suddenly, the MG went from “peaceful cruiser” to “budget airline taking off in a storm.” My partner described it as a plane taking off, and honestly, I could only nod while also hearing a delightful high-pitched wind howl for extra immersion.
Now, since we’re planning a grand adventure across England and all the way to Switzerland this summer, I’ve come to a simple conclusion: this ain’t it. Five hours of being serenaded by screaming wind demons, followed by twelve more hours the next day, sounds like a one-way ticket to insanity. Plus, I don’t want to be messing with it every time we stop.
So, where does that leave us?! Good news for the MG forum, I guess!!! You're getting another thrilling episode in my ongoing saga! We’re going to give the Thule Evo Clamps a shot, and I’ll start a new thread for that (because ev-mania must be documented properly), and I’ll link it here.
Thanks for posting this. I will probably give these a try.
(Before I go pulling the head lining down and drilling/welding to a brand new car.)
I will only be fitting when there is a roof load on (large tent bag and misc gubbins) so any noise will not be from the bars.
BTW
I used to get the awful howling/drumming on my DIY bars on my old land rover. This was due to the vortex shedding on the 1" box section I used.
To fix this, I wrapped a bit of rope three of four turns along the length of the offending bar. In the same way you see a spiral down the length of tall thin chimneys.
It looks crap, but works.
Also the high pitch whistle from the short hollow uprights, till I plugged them.
We have had Thule evo bars, the ones that are shaped more like a wing, compared to a previous type that was just square box and the sound was noticeably less.
I even had the EVO bars for the first ZS EV we owned, they had a dedicated kit for the roof bars ours had and it worked fine.
Nowadays we sold the roof bars and the roof box. The kids are bigger now and bigger kids require a lot less bulky items when going on holiday AND our main car (mine, the ZS EV is the wifes car) has an enormous amount of space in the car.
People sometimes laught a bit about the underfloor trunk and the frunk, but the amount of stuff we can carry in those is incredible to be honest. Those 2 easily takes as many bags as the Thule roofbox we owned and it was not even a small one.
Thank for the feedback, the main reason we need a box in the first place is because we have two dogs and two kids. So the place in the boot is quite limited and mostly taken up by the dogs
BTW
Decent idea, I might just try both
The short hollow uprights I mentioned were on my old land rover bars. But any open ended tube will whistle in the wind.
My SUP-055 bars arrived.
I can confirm that they do indeed fit my facelift ZS LR EV SE.
I can only get the bars about 60cm spaced, before the profile gets too thick that the side plates (that hook into the door shuts) run out of adjustment. My tent bags are quite long, so I may make some mods (or new/longer hook plates) to allow the rear bar to be mounted a bit further back.
Thanks Chris for the heads-up on this solution.
I am looking at the possibility of making up some sort of under-bonnet stowage cradle. I wonder if there is enough space under there for the spare wheel, tools etc.(I carry a small trolley jack, instead of the scissor jack). And free up the dry under-boot space for more storage.
(EDIT: Not enough room for the spare.)
I have Brio bars (occasionally available from Lidl) on my MG5, which posed the same symptom. These bars have an open slot underneath. The front bar in particular was the source of almost all my whistle. All I did was press in a length of plastic hose I had to hand, which just happened to be a snug fit in the slot.
No more whistle.
The SUP 055 bars come with a length of insert strop to cut and seal the slots.
I have prototyped up a custom clamp for these bars to allow the rear one to be set much further back, as I have long loads to carry.
Am looking to try one of the online services to have some laser cut. If they are any good, I'll make the artwork available if anyone else wants them.
Thanks for the detailed breakdown, super helpful!
Which thule clamps are you trying? Any joy?
