Don’t be surprised if the clicking comes back after it is replaced either then ?.I'm surprised so many on here are trying to fix it themselves.
If you have movement in the steering column, then that might be either the universal joint failure problem, or the problem with the bolts that secure the steering mechanism to the bulkhead.I have this clicking, I only bought the car a few weeks ago (2024 ex-demonstrator, 1,800 miles), so took it back to Hendy, where I bought it asking them to fix it. They came back with:
"Clicking and movement in upper steering column, trip procedure followed but noise still apparent - new upper column required. Repair price: £1316.16"
Then a note to say it would be fixed free under warranty and booked the car in for when the parts arrive.
I'm surprised so many on here are trying to fix it themselves. Don't these cars have a 7 year warranty or something?
I suppose that the steering replacement it's not necessary because there is no explanation if there is any difference between the old and the new steering column. All the users that report this clicking problem do not report any mechanical wear or structural weakness on the steering column.... Maybe what solves the problem is the screw readjustment caused by the steering column replacement. Can you inform them (MG mechanic's workshop) about this procedure and obtain any reliable feedback? In my case just made the "clicking" report to MG in the annual mechanical review past July, and what they have done has they mentioned in the intervention report was "multiple ajustments" but clicking remained... After that I started seaching on the internet about it and reached to these procedures... Next mechanical revision, if the "clicking" returns will be reported again... About the 7 years warranty, in my country (Portugal) I think that it only covers battery.... But I'm not sure....I have this clicking, I only bought the car a few weeks ago (2024 ex-demonstrator, 1,800 miles), so took it back to Hendy, where I bought it asking them to fix it. They came back with:
Has your “clicking” stopped now after you increased the torque on the steering column clamp bolt ?????.I suppose that the steering replacement it's not necessary because there is no explanation if there is any difference between the old and the new steering column. All the users that report this clicking problem do not report any mechanical wear or structural weakness on the steering column.... Maybe what solves the problem is the screw readjustment caused by the steering column replacement. Can you inform them (MG mechanic's workshop) about this procedure and obtain any reliable feedback? In my case just made the "clicking" report to MG in the annual mechanical review past July, and what they have done has they mentioned in the intervention report was "multiple ajustments" but clicking remained... After that I started seaching on the internet about it and reached to these procedures... Next mechanical revision, if the "clicking" returns will be reported again... About the 7 years warranty, in my country (Portugal) I think that it only covers battery.... But I'm not sure....
Hi! Answering to your question, before increased the torque on the steering column clamp bolt (first image), before I had made the procedure (second image), after that both procedures until now no clicking. One thing that i have noticed, after increased the torque on the steering column clamp bolt, was that before the steering wheel when manually forced up an down was moving a little bit, after that does not move at all.Has your “clicking” stopped now after you increased the torque on the steering column clamp bolt ?????.
Today I found a little time to take a very quick look at the upper securing bolts section on the steering column of our 2022 Trophy ? LR.After these two procedures, it only remains to tighten the bolt under the scuttle panel, see picture... Some info I read was in this forum, in this old thread An update on the increasing play on my loose steering column :)
Maybe we need the three procedures all together, and perhaps someone with proper tools (torque meter) can give a complete and definitive solution to the problem, and make a video tutorial with torque values to show MG how to solve the problem!![]()
