MG4 202022 Fast Charge
Luke Atkins
Poole, UK
MG4 (2022-2025)
Hi
The Fast Charge on my MG4 Trophy EV is not working. It broke in November. The dealer have confirmed that there is an issue and are waiting for a fix from MG UK. Do other people have this issue? Despite chasing the dealer, they are unable to fix the issue or give me a date for a fix.
Any help or advise much appreciated.
What do you mean by Fast Charge? To me a Fast charge is anything from 7kW AC and upwards. Once you get to 50kW DC you're into the realms of Rapid charge, and then 150kW+ is Ultra Rapid. (Just trying to ascertain if it's a home charging problem or an On The Road [DC] charging problem).
What model year is your car? Does it have a single or 3 phase onboard charger? (You can tell by looking at the charge port - if there are metal pins in the L2 and L3 slots then it's 3-phase). If it's a 3-phase OBC then a CCU failure was quite common on those cars.
Hi
I mean rapid charger.
My car is an MG4 Trophy EV, 2022 registration. Here is a picture of my charge point. I assume it is 3 phrase - please confirm.
If it is a CCU failure what are the next steps.
That 2nd image shows pins in the L2 and L3 slots, so yours has a 3-ph OBC. This sounds very like the CCU failure issue .. this is well-known, and means a new CCU (from memory). Some others here (like @tsedge) have had this very issue and had it resolved; mine is an SE SR so single phase so I can't give a chapter and verse answer, sorry.
Search this forum for CCU might throw up relevant threads, such as:
    Votes: 1,081 77.8%
    Votes: 208 15.0%
    Votes: 102 7.3%
