MG4 Doors not closing properly?
Collected
aylesbury
Has anyone else had an issue with the doors not quite closing properly when you first close it without slamming? Did you get an adjustment?
The door rubbers could need bedding in but should be easy enough for the dealer to move the catch slightly.
Yes I get that. But it is not untypical for a new car to need to overcome the internal pressure to close properly.
It is not a defect.
It is not a defect.
Agreed. My old i3 used to drop its window a little way when you opened the door so that internal pressure didn't make it harder to shut the door. Then the window went back up once the door was closed. I tried shutting the door on our MG4 with the window slightly open and it took less of a push. My wife quite often only half shuts the door on the car!
    Votes: 1,096 77.7%
    Votes: 212 15.0%
    Votes: 103 7.3%
