MG4 radio issues
AWP617
Hemel Hempstead
I have an MG4 Trophy bought in November 2024. I have an intermittent problem with the radio. Every now and again (about once or twice per week) it just freezes. When I stop the car, lock the doors then restart, the radio is almost always working again. No problem with BT audio or online audio. I’ve had the software updated, but it’s still the same. Any one else have this issue ?
I use the USB C as a music source and occasionally that freezes or plays no sound.
I can press the arrows below and toggle through music sources and the radio and that seems to get it going again. It may work for your radio problem and save you stopping and locking the car.
* Not my photo
This is how mine 'functions' when I first drive the car after being locked (s/ware is R59):
50% of the time it will play the radio station (RDS) which it was left on when the car was locked.
30% of the time the radio station is correctly selected but the radio is paused - a click on the right steering wheel button will play it.
20% of the time the radio function has reverted to the icon shown above and needs a tap on that icon to open the radio screen - the last RDS channel is automatically selected and play automatically resumes.
I’ve had the same issue on my XPower which I took delivery of in December 24.
Radio will randomly just stop/pause at times mid drive with no way of restarting it.
Haven’t yet found a reason why or a solution 🤷🏼‍♂️
Took delivery of the ZS in December and have found the radio does not switch on at startup at least 60% of the time, have to hit the mute button to get it going, dealership say they can’t make it do it but I think I’m being fobbed off. Have opened a poll to find out how common this is!
The solution for me is to press and hold the home button until the system resets and then the radio then works. It saves having to do the full, get out of the car and lock up business.
I've never figured out why it happens (maybe 1 a month or two) but this always sorts it. Hope that helps a bit
Which infotainment software version are you on?
r30 sw and dealer reloaded software all ok I notice the play/pause indicators are oppersite positions on the radio and the top left of the screen
I still can’t get weather update though, implementation failure error
Worst radio I have ever experienced in a car (and I can remember valves and transistors). Totally unpredictable as to it working or not. May work then go silent after a random time delay. Other music sources work so it's the DAB radio rather than the audio system. Inforpainment reset (hold Home button) usually gets it working again but you have to fiddle around to get the favourites back. Seems better if you've previously driven the car (e.g., after parking at the shops).
I’ve found that a USB memory stick plugged into the RH port (so the USB-C hole) via an adaptor will often cause the system to behave strangely. I think the entertainment system does not tolerate corrupt USB storage at all. Even memory sticks that have worked for a few days seem to go this way and then when I remove them and reformat/re-copy on the MP3 files they behave for a while but eventually the entertainment system will start going on the fritz. Remove the memory stick from the RH port and suddenly all is well.
I also have this split.
By the 20% fix is hold the home button for 10 seconds and let the whole thing reboot.
I am still trying to work out what triggers the "working" radio, or "paused but working" radio split.
It's about as random as the bluetooth connecting to the phone or not
    Votes: 1,078 77.8%
    Votes: 208 15.0%
    Votes: 100 7.2%
