Deleted member 9909
- Sep 18, 2022
Gnarf, gnarf...well I never matronI know, I'm having treatment, but it's so hard at times?
Wow, I'm cured-no more cereal me?
Maybe the next run set the battery preheat for before you set off and see if it makes a difference?Well more odd behaviour tonight.
Made sure everything speed related off, it didn’t stop at 70mph like it did last night, but it did stop at a ‘higher’ speed (nowhere near the claimed 100mph top speed)
It’s definitely holding back, it should go much faster.
I’m wondering if it’s battery temp related as yesterday was freezing and today much milder.
And my commute is short so I’m demanding high speeds within a short time.
Whatever it is it’s bloody annoying me as my Leaf went up the same hill much faster, no drama.
I didn’t buy the 4 to be slower than the Leaf!!
What a baffling, odd car this is….
Could it be a temperature related thing? Perhaps below 4c it doesn't like Sport mode?I had it the other day when I tried the car in sport mode .
Found that it doesn't like sport mode and keeps going into snow .Although the driver display shows sport .
Have a look .It may be that yours is doing something similar
There's a cure for that ?I know, I'm having treatment, but it's so hard at times?
Are you flooring the throttle or being more progressive about it?
There is some problem with your car if I put my toe down in ours let's just say it will goWell I had a repeat of the lumpy/slow acceleration and restricted top speed tonight (low 50s mph)
Guess what percentage the battery was at….
Yup, 40%….
I think you have a MBS or battery issue. The car doesn't really seem to know what state of charge it has and this could be why you are also getting poor range as 100% indicated isn't a full charge. 40% is not a low charge and you shouldn't be seeing restricted power until a much lower charge.Well I had a repeat of the lumpy/slow acceleration and restricted top speed tonight (low 50s mph)
Yup, 40%….
Just had a thought on our MG ZS EV MK1 you can view the battery voltage, motor speed and current on one screen, can you do this on the MG4, and see if the voltage collapses in the situation above, as this would indicate the BMS doesn't know the true SOC potentially due to not balancing fully or a fault battery packI think you have a MBS or battery issue. The car doesn't really seem to know what state of charge it has and this could be why you are also getting poor range as 100% indicated isn't a full charge. 40% is not a low charge and you shouldn't be seeing restricted power until a much lower charge.
