Only set the charging schedule on either the car or your charger not both. Given the choice I'd set it on the Ohme charger.Hi everyone
I have just had my ohme epod home charger installed,
I am a bit confused do i schedule a charge through my MG app or my ohme app?
Any help appreciated.
thanks chris
What electric tariff are you on?Hi everyone
thanks chris
Octopus intelligent.What electric tariff are you on?
Thankyou will try that.Only set the charging schedule on either the car or your charger not both. Given the choice I'd set it on the Ohme charger.
I have this combo - I set the limit on the MG4 (eg 80%, 100%) and I have a standing programme on the Ohme to charge during the cheap hours.
What version of the MG4 do you have m8? Trophy/Luxury can adjust the charge level I think the SE can't... Correct me if I am wrong.I've got the Ohme Home Pro - But I can't seem to get the car to stop the charge at 80%
Ohme have said that they have MG4 on the roadmap to build in the API so the charger can read the battery but in the mean-time I'm trying to set a healthy / battery safe limt on the car?
I slide it on the APP to 80% but it seems to charge past that, is there a certain order to do it?
Kindest,
Presuming you have Octopus Intelligent?I've got the Ohme Home Pro - But I can't seem to get the car to stop the charge at 80%
Kindest,
Hi everyone
thankyou
Hi ChrisHi again
If i set the schedule on the ohme app it doesn't give me a start time, I want it to start off peak. Also if i put the price cap on it shuts off the scheduled time.
Thankyou
So the best I can explain it is that the Ohme knows your model and knows what charge it can take, but not what's currently in the car. When you set 80% on the Ohme or Ohme app, you're asking it send 80% of the model's total capacity down the cable.I've got the Ohme Home Pro - But I can't seem to get the car to stop the charge at 80%
Kindest,
That's well put, and also worth noting to change the slider on iSmart app if you want to charge to 100% periodically (either for long journey or for cell balancing) as it can interfere with with the Ohme if notSo the best I can explain it is that the Ohme knows your model and knows what charge it can take, but not what's currently in the car. When you set 80% on the Ohme or Ohme app, you're asking it send 80% of the model's total capacity down the cable.
The MG iSmart app has a slider under "charging management" for you to set the target charge. When your battery hits that charge level, the car will cut off charging no matter how much more the Ohme is expecting to send.
I hope this helps.
I have the SE - Why would this be limited for the SE? I did see the toggle at one point but never seen it again since.What version of the MG4 do you have m8? Trophy/Luxury can adjust the charge level I think the SE can't... Correct me if I am wrong.
If using a granny charger I'd suggest just using a standard plug timer as a work-around.I set up scheduled charging for the first time today but it's a bust and I can't figure out why?
I'm at home on a granny lead only, thought I'd schedule it to make use of peak solar energy between 10am and 4pm. Plugged it in and set it up via the app at about 7am. All fine.
At about 7.45 am it started charging. I went to the car, the infotainment still says "charging scheduled" and the times 10am-4pm are there. I stopped it charging and set it again. 10 minutes later it's charging itself again!
So I've unplugged and will manually plug in at 10am BUT can anyone explain this?
[As I've seen these questions asked in other threads about this, some info: The clock is set to 24hrs, both the app and the infotainment screen show the same information about settings and on/off status is synced. There's nothing to indicate the setting wasn't saved as both app and car showed the schedule.]
You don't want the schedule in both the car and the app, one or the other. Don't forget there's an up to 10 minutes random delay on scheduled charging due to National Grid rules.I set up scheduled charging for the first time today but it's a bust and I can't figure out why?
Once I got my head around what to do with the Zappi I have had no problem with scheduled charges. I only use the MG app to set the charging limit to 80%. I did do a full charge the other day over 2 days to get the car to 100% as per suggestions of charging the car to 100% once a month. I just adjusted the slider on the MG app to 100% but otherwise used the Zappi app to schedule the charger for two 4 hour sessions at off peak rate.You don't want the schedule in both the car and the app, one or the other. Don't forget there's an up to 10 minutes random delay on scheduled charging due to National Grid rules.
I have a Zappi and I schedule on the Zappi only, not the car, and this works fine. I couldn't get it to work from the car.
