MG4 X Power Vibe/Hum 65 to 75mph
The sticker doesn't have any.date on mine. But I pulled the factory sign-off out and the manufacture date was 16/11/2023. So I'm assuming they had my car in a lot in China already when my order was placed.
So that date falls in the, any X Power made after October 2023 shouldn't have the vibes. And as you've said, yours doesn't. Result! ??
I've looked at a couple of those stickers, can't see no date on um. ?
Ah ok...mine has the date stamped on it June 2023 which is inline with the certificate of conformity
My sticker had a hand signature over it rather than a date stamp. I imagine this is just a method of the factory quality controllers keeping track of which of the thousands of MG4s in the lot they've actually checked and some use the stamp. My guy clearly couldn't be arsed with all that and just put squiggle across with a pen....not sure if that's a good sign or not haha
Mine arrives Thursday and I'm really hoping it's not there but can report on delivery day.
It didn't stop me ordering one though and I didn't notice it on my demonstrator, I don't know when the demo model was built though.
Do we have clarity on the 24 models not being impacted ? I am sure i have seen people mentioning.
From what I've just discovered, a vehicle ordered and registered in the UK in 2024 may have actually been manufactured several months earlier. If the fix was introduced October 2023 in the manufacturing process it's not inconceivable that a 2024 registered vehicle still has the issue when you think my own vehicle was registered April 2024 but manufactured November 2023. I think it's quite probable that you have vehicles with registration dates January to March 2024 that were manufactured under the old process and therefore have the issue from production.
I think the only way you can be sure is to take the new car for a drive before you sign for it(if you can), then reject it if there is the vibration/hum.
This is the problem with no announcement or news from MG to state that all cars supplied from a certain date have the most up to date parts fitted.
But that would mean they would have to admit there is an issue...at the moment they are saying it's a characteristic of the car...which they obviously forgot to add to their X Power sales brochures and marketing?‍♂️
As above, and take the salesman with you.
But if it's a so called "characteristic" of the car. Then why are MG supposedly trying to fix it. And again X Power's made after say Nov 1st 2023 apparently don't have the vibe. So doesn't that prove there was a fault in the 1st place. ?
Yeah, all a load of BS, the fix is going to be costly to MG....I've got to the point of my first service coming up and have asked for my issue to be logged and the dealer wants the car for 3 days for diagnosis and testing, we are just going around the buoy.
Also, to try and put me off, if I want a courtesy car, then that won't be available until 28th Oct and at a cost of £24
But what grips my shit the most is other X Power drivers who are lucky enough not to have the issue...make comments to people that have problems that it's in their heads...there is no issue, it's a sports car so will vibrate, the car is cheap, people complaining are a just moaners...live with it...simples, just send the car back?...not sure what planet these people are on.
It's like EV Haters but X Power drivers hating other X Power drivers...I'm sure you have seen some of the posts
I'm not on FB so not seen anything, but that is dissapointing to say the least.
I struggle with some of the waffle seen on here tbh, (and have been suspended for saying so ?) so to have it from all your family and friends (not all of them obvs) as well, would see me committing Hari Kari. (Not sure you can say that anymore??)
I mean, how many bloody pictures of dinners, sunsets and soppy quotes do you need in your life?
More about it here from an unhappy UK MG customer :-
It's a long video so be warned !! ?
and MG Austria appear to be the source of @seamust1000 post above:-
From Facebook "MG 4 X-Power Vibration Complaints" group :-
"I'm not sure if many of you follow the MGEVs community forum but there has been lots of posts about the vibration since Sept 23...a guy in Austria has had his car tested etc and this is what he says 6th August 24(google translate)
Hi guys, so, MG Austria just called me back, the tests on an XPOWER for months and there are also LUX vehicles affected recently.
Basically, it should be noted that a very nice constructive and competent consensus,
the statement was following, yes, MG knows about the problem, SAIC, how can I best say it,
is partly silent, which is not exactly pleasant for MG Austria/ Europe.
You would like to see more cooperation and thus, for example, MG Austria is pretty much on its own.
The car was literally completely disassembled, springs were exchanged, dampers were exchanged, a coilover suspension was installed and driven at different heights, the rims and tyre combinations replaced (from premium manufacturers to cheap suppliers), the axle suspensions were reinforced, the drive joints replaced, etc.
What has come out of it, as I said, the vibrations come from the HA and NOT from the VA, that has just confirmed to me MG Austria in the conversation,and since it is now also the case with the LUX that these problems occur and which has only 1 motor and which also sits at the back, well ...........
SAIC now quietly has another (new) part number of a rear drive shaft (presumed to be right) in the system,
This has already been ordered by MG Austria, but it is currently only available to a limited extent...
As soon as this arrives and has been installed is tested, and everyone at MG Austria believes in this trigger...
He also mentioned that VW and Tesla also had these problems, after massive interventions a replacement was quickly created here and the new drive shafts are / are now installed and there are no more problems.
SAIC produces/leaves these waves and had (so it is assumed) some (any amount) of the so-called old ones still in stock...
MG Austria has assured me that I will know about the result and if the test (which is assumed to be) ends positively,
The new wave will also be rolled out quickly to the XPOWER and LUX drivers.."
Quite a long post.
From October LAST year!
Good Morning Ryan
I hope you are well.
I am sure you remember that last month I brought to your attention that my vehicle displayed a light vibration between 62-74 mph.
I also spoke to a chap in your service department about it.
I think I am right in saying that I was one of the first people to own an X Power in the UK so of course, the issue was not well known about.
I now know that MG is looking at the issue and now taking the matter seriously.
It would seem that every X Power subsequently delivered, here and abroad has the issue.
MGAustralia, has paused deliveries to customers, on the back of the UK owners complaining to MGUK.
MGUK have told us to refer the matter back to our supplying dealer which I am doing now.
I fully expect to be contacted at some time in the future, asking me to book the car in for a fix.
Nobody knows what this will be yet, but MG are suggesting a steering damper will be the way forward.
If you are unaware of this, please can I point you to this articles.
Please be kind enough to respond to this email.
Kind Regards
Chris S.
He never responded.
So I wrote to MG who did respond.
Dear Mr S.
Thank you for contacting MG Motor UK Ltd.
I do believe, that there is some confusion regarding processes that are and need to be followed.
Firstly, some customers are reporting this as an annoyance. Therefore, any action that we take is being looked at case by case.
As far as I am aware some customers are reporting vibration at certain speeds, but it is not having detrimental effect on the car or causing breakdown. If there is anything that your local dealer can do, in conjunction with MG Motor UK Ltd. then I am sure that will take that action.
To be clear, Australia are their own distributor and we have no affiliation other than the badge and have no influence on any decision that they make. All that I can say is that any repair they are carrying out will not be an official opinion or process from the factory.
As with all things, when new models are launched, things happen that don’t show up in testing, but show up when with drivers in real life conditions.
If a fault or problem is concerned, then engineers will test this, and provide a solution, and I may say, that because of our unique set up in the UK, usually much quicker than most OEM. I have worked with several brands and may take years to provide solutions to these things.
At the moment, everything is simply being looked at case by case and thank you for your continued patience.
Your Sincerely
Gary Smart.
Fobbed off obviously ?
Wrote to them again with all the findings I had on the issue so far.....
Good Morning MGUK
Now I know that even before I finish this email, you will refer me to my supplying dealer, so I will not go to great lengths to explain my issue.
This is purely so you can add me to your list of disgruntled X Power owners.
I have a vibration through the car/steering wheel at anything between 60-75 mph.
It is now very well documented around the world.
MG Australia seem to be taking the lead on this issue and are developing a fix.
They have also stopped delivery of X Power to customers until the cars are fixed.
When will we hear something officially from MGUK regarding this matter?
Yours sincerely
Chris S
MG 4 XPower deliveries paused as key tweak is rolled out
Hi Chris
Thank you for this, and I will certainly forward to our technical team for reference.
However, we wouldn’t be able to recommend or confirm this, as its not an official process etc.
Gary Smart
Customer Service
Fobbed off X2
Now I've been very patient, largely because I have a minimal issue but also because I knew full well that they would not take any notice of me on my lonesome, so even though it's been a year I do see some light at the end of the tunnel.
Truth be told (and it is) I thought about rejecting the car the first week I had it.
I had a few days driving holiday straight off the forecourt as I've done with all my new cars, so I can get to know it intensely.
I knew it wasn't right within 5 minutes of driving off because I almost immediately got on the A48.
I put it down to a tyre being out of balance and didn't worry about it too much.
I wasn't best pleased though, because this had never happened to me on any other new car I'd purchased.
I was in the Honeymoon period and I was off to spend a few nights with my new bride and was prepared to forgive her anything.
The rest is well documented on here so I will not got over it all again, but my suspicions were initially the front driveshaft or shafts for obvious reasons.
(But seems now to be a rear driveshaft)
I also knew that a damn site more folk were going to have to complain for me to see any sort of resolution.
That tipping point seems to be well and truly surpassed now and I see it being just a matter of time before I get a letter asking me to attend the dealership for my fix.
We shall see.
I mean come on MG, ENOUGH ALREADY!
If not, I see a Mass Action Claim in my future.
If MG do make any mechanical changes will the E11 codes get updated, has anyone with cars made in 2024 got different codes to these from a 2023 car? (on my car these are on the drivers side rear door b pillar)
I've had this message on FB from a mysterious person, not sure if they work for a dealershipView attachment 29771
be interested to see if they actually fix it..
Like i said in very skeptical myself ..
dont meant to sound negative but this gives me a little more hope they may do something !!
