securespark
I think we've got down to 12% in our LR Trophy and it's been fine. It just bleats all the time about being low!
I guess much lower and it might start crawling.
Ah, OK!I think @bedsev was crawling because of the weather and traffic, not because of the car.![]()
Quite surprised how ‘poorly’ the X Power goes at lower end of the battery, and not even that low, at 26% i felt sport was well restricted.
When i had the Tesla it maintained full grunt right down into single figure percentages. At 26% it would pull as if 100%.
Maybe the standard Tesla but not the performance version.Quite surprised how ‘poorly’ the X Power goes at lower end of the battery, and not even that low, at 26% i felt sport was well restricted.
Whenever I start to notice low range potential ( as that's what it actually is according to how you drive ), I simply ( while driving ), reset the odometer which resets the ( potential ) range to to a more realistic number, thus lessening the 'range anxiety' and top up stop.I've been letting my X Power, get pretty low before charging. Down to less than 10% the other day was 5% and it did get a bit worrying. I'm gonna try and stick to charging it when it gets down to about 30%. Also because, apparently you don't get the full performance at less then 30%
Although it still feels pretty quick to me, at less than 30%![]()
All you're doing is playing mind tricks on yourself ... you don't magically get that extra range.Whenever I start to notice low range potential ( as that's what it actually is according to how you drive ), I simply ( while driving ), reset the odometer which resets the ( potential ) range to to a more realistic number, thus lessening the 'range anxiety' and top up stop.
Nothing that doesn't require you to set it going.
It will be near enough but is near enough good enough?
(70% Battery)
I shall be going out early on Sunday with a fully charged battery and hopefully get some quicker times.
In cold temps, our xpower is noticeably down on grunt when battery is stone cold - after a few miles, once there is some heat in the battery, normal brutal service is resumed.
