MG5 EV Electrical Issues
lovejoy61
Leeds
Flickering lights clicking starter button won't turn off and had a new 12V battery fitted. Anyone help plz this is my mg5 ev
What is the 12V reading on the dash in 'ready' mode should be about 14V. Try connecting to your EVSE.
Electric vehicle supply equipment or 'charger'
It's been checked its fine had it checked
Has this just started after fitting the new battery? If so, have you checked it's actually in a properly charged state?
It all started after a garage had it a week during the cold and snow fitted a new head light it had 33% of main battery on it but when I picked it up it had only 7 after that it went hay wire wouldn't turn off temperature up and down
Could be a long shot, but there have been a number of reports on this forum of weird electrical behaviour as a result of water leaks to the driver footwell from the rear screenwash pipe located in the offside A-pillar affecting various electronic boxes. The joint can leak if the pipe freezes
One such report said that the MG5 would not turn off.......
Right not 100% but I tried rear wiper to clean but nothing but front ok might be worth looking into 👍
If the rear screenwash is not working but the front one is that could be an indicator of the pipe coming adrift.
take a look at this tread
also this one
the experience of user @M44LCY may be of particular interest to you in the second link
Morning pal ive just checked and under the polystyrene thing there was water wonder if thus could be the culprit
Also when this morning b4 this I tried using the rear washer no fluid but strange sound from near the speaker on drivers side
Definitely sounds like the washer pipe has become disconnected. First thing is to get that fixed and get rid of any water. As you'll see from the posts linked above, this has happened a lot
