MG5 Exclusive LR - minimum charge kW power requirement
BravoDelta
Surrey
Will the car charge if there is less than 1.4 kW available?
I have seen a comment on another website that some other brands of car have a low power AC charge setting. The person mentioned theirs will still charge even as low as 600W.
I have solar PV and want to use as much of this as I can.
We are very happy with our new car - not done many miles yet but switching to BEV motoring has been easy to get used to. Still lots to learn though.
I think I am probably misunderstanding but my solar runs into an inverter which changes the DC to AC and sends it into the grid.
So I if charge when I have excess solar it just effectively takes less out of the grid: the car still charges at the same rate.
It doesn't matter if I am not producing enough to fulfil the car's requirement.
I suppose if you are off-grid it might be different.
EVs in general start charging at 1.4kW. With Zappi I can set a percentage green, say 70% so it would charge with 1kw.
You can only usually charge at a lower rate once they exceed 99% to fill up.
