jhinshel
I have an EVSE with a viridian EVSE Protocol Controller (EPC). I was able to match my PV generation with the charge rate on my nissan leaf by adjusting the resistance between the IC pin and ground. The resistance on the IC pin cause the EPC to adjust the control pilot (CP) signal to the vehicle. the vehicle adjusts the charge rate accordingly. This does not work the same on my MG5.
Has anyone got experience of dynamically changing the charge rate of the MG5 on a type 2 EVSE?
I am wondering if it may be possible to adjust the resistance between the proximity pilot (PP) and ground but I suspect that this may just set the charging power for the charging session and will not be adjustable in the session.
