Joningy
MGS5 VIOFO A229 Plus 2K +
I've decided after a lot of research to fit the above dash cam, it appears to be a good compromise between quality, reliability and useful features, without costing a silly amount of money (it still isn't cheap @£230 + fitting kit + micro SD card + other hidden bits which invariably crop up) also decided on HK4 Acc Hardwire Kit and Integral 256GB High Endurance Security micros, I've used Inregral before for photography.
I currently have a Redtiger on my current MG4, but since I fitted nearly 2 years ago, things have moved on a lot, although I have no problem with it, the spec is not as good as VIOFO 229 plus.
Has anyone yet DIY fitted one to an S5?
Although a competent DIY'er, modern car electrics are pretty complicated and I don't want frick it up, only driving it home from the dealership.
Routing cables is relatively simple and straightforward, I'm a stickler for having as near zero cables showing as possible, but I'd love to know where is best to connect the feed, as the MGS5 USB feed to the rear view mirror region, I believe is not a continuous live feed when ignition off (ignition seems a funny word on an EV
Wouldn't it be nice if I can trace the mirror USB feed back to the fuse box and alter it to constant live (to enable the parking mode protection) but I very much doubt it's that simple!
Any pointers would be great, thanks guys.
Regards John.
Regards John.
