MGZSEV Reduction Gearbox Oil Mist
LeoRBK
Sale
ZS EV
Popped open the bonnet of my MK1 ZS EV to top up screen washer. Signs of a suspicious leakage?
Is that the gearbox breather I see?
That is the breather, some (like mine) are blanked off.
I think I would get the oil level checked. Either too low or too high could cause the problem.
HI.
I have same problem in the gearbox, after long ride i see leak.
Did you find what is the problem?
Do you see visible signs on floor under the car or could it be mist like I noticed?
Ok,
I did not follow up on my case since it was confirmed to be a mist and is expected.
Gearbox leak on ZS EV is not commonly reported issue, I would advise you to ring the dealer with photographic evidence.
he did not indicate, did he change the oil in the gearbox? If they changed 1, they filled in more than the norm, 2 - oil of a different viscosity. We have summer in Israel now and the temperature is high.
