Yes I press the two on the left, so it blasts the windscreen and it does go away but once I turn it off it all clogs up againMine seems to stay at the last setting I had it at. I agree that "recirculate" causes the windows to fog up. However I have been generally impressed by how well the car demists. Just press that demister button and it all goes away.
Yes, keep the Air on and make sure it's set to External Air mode (whatever it's called!)Yes I press the two on the left, so it blasts the windscreen and it does go away but once I turn it off it all clogs up again
I wonder if for some reason my car has a lot of moisture inside.
I’m thinking of putting a dehumidifier inside or has anyone got any other suggestions?
I never need to nor have wiped the inside of the windscreen and it has been very wet here over the last few weeks.Is it just me or is there a lot of moisture in others cars too?
I feels like it’s the same as wiping the shower screen when I wipe the windshield
Aye bit hiv ye no goat palm trees 'n' 'at doon aer.I never need to nor have wiped the inside of the windscreen and it has been very wet here over the last few weeks.
I always have AC on set to a low fan speed with demist and upper vents open, usually I set it to 22C or 23C. To clear I use the demist button which works within a few seconds, it is pretty quick to clear it.
That's called Air Conditioning ... perhaps use it?I want to take the moisture out
Pardon? I need a translation for that one.Aye bit hiv ye no goat palm trees 'n' 'at doon aer.
As has been pointed out and as I said using the air conditioning will eliminate the moisture since it acts as a dehumidifier. If this isn't working then maybe you have a problem with water ingress.Demist doesn’t take the moisture out of the car it just clears it from the window
I’ve seen these moisture absorbing pillow things might give that a try
It's either Doric or Geordie, or some unholy inbetween.Pardon? I need a translation for that one.
Try looking on utube for Robert Lovie reciting poetry by Ian Middleton. “Passion Pooder” is a good starting point or “Auld Jock’s Drawers”.Pardon? I need a translation for that one.
Canny accuse mi i bein' Doric Mr Bo'ness (Archev). Am fi nearer you urriginally.Try looking on utube for Robert Lovie reciting poetry by Ian Middleton. “Passion Pooder” is a good starting point or “Auld Jock’s Drawers”.
Wonderful Doric.
Fairly ‘at aye bit my wife Wis Banchory QuinneCanny accuse mi i bein' Doric Mr Bo'ness (Archev). Am fi nearer you urriginally.
