Alb
Moderator
- May 11, 2021
- Solutions
- 3
- Location
- MG5 Mk1 SR
- MG5
Although those of us installing a fixed charging point at home end up using one of a limited range of boxes, our individual homes and supply arrangements are unique so the purpose of this thread is to share some of my thought processes and experiences in the hope that some elements at least may be useful to other members.
I allowed a couple of months to elapse between delivery of my MG5 and installation of a 7kW charge point. There was no time pressure in my case because in the short term at least, the good old Granny (backed up by a free Pod Point at my local Tesco) met my needs.
I wanted a reasonably future proof solution at a decent price and the HyperVolt ticked all of the boxes for me. Although many of the charge point manufacturers have recommended installers, I chose to seek a local installer because I wanted to use the opportunity to have my Consumer Unit upgraded to an 18th Edition box at the same time. Finding a good electrical contractor became a saga in its own right but I have a separate thread about that here: Choosing a charge point installer
My installation will be easier than many because my consumer unit is in the garage and the charge point was to be located on an external boundary wall meaning that most if not all cabling could be kept internal. Here's a picture of my original Fuse Box (and it was an old fashioned Fuse Box dating back to when the house was built) fitted in the left hand rear corner of my garage:
The charge point was to be located on the outside of the right hand wall close to the door:
This is the other side of that wall and the location where the charge point will be fitted:
On installation day it took just a few hours to install the new Consumer Unit. All outgoing circuits have Type A RCBOs.
The EV cable was routed in 6mm² T+E through the loft space to be dropped down in 25mm conduit alongside the two existing circuits adjacent to the garage door. A 32A isolator was also fitted at this location.
The 25mm conduit was routed to a terminal box and a hole drilled through the wall. The hole was vertically positioned to allow the cable to come out on a mortar line just below the gland entry location on the HyperVolt box. The cable you see here was replaced with a 32A black flexible rated for external use.
There is a small amount of cable visible with the box installed and charging cable unwound but you don't see it at all when the cable is stowed.
Close up of the cable entering the gland.
The finished job inside:
The finished job outside:
All of the installation work here was done by Jack and Luke of JTD Group.
Jack Davis is the company owner.
