unbornidentity
- Feb 3, 2024
- Gloucestershire
- MG4 (2022-2025)
Had a software update to R33 as my car didn’t have an outside temperature display.
That is now working but it appears they may have updated more than just the infotainment.
Before the update the car wouldn’t AC charge unless the car was locked even if you pressed “start charging” but I’d only ever get blue or green port lights. Now (after the first charge since the update, which worked like normal) unless the charge starts immediately (I’ve got an Ohme) I get red charge port lights. If I override the Ohme schedule and get in the car and press “start charging” the car starts charging (which is good).
Was a bit concerned it wouldn’t charge overnight as now after plugging in the port goes red so locked the car then overrode the Ohme schedule and after about 20 seconds the port went green and it started accepting charge.
The odd thing is now, when the charger isn’t connected I get yellow port lights! So basically, yellow with nothing connected, red when not getting power from the charger and green when charging. Anyone else seeing this happen?
Cheers
Cheers
