New to electric
Not quite correct. For my area they are very close however (about 0.3p/kWh more expensive for Go).
Well yes for the difference of less than half a pence per kWh I was treating them the same for simplicity but of course you are correct ?
That's definitely true in principle but the EV tariffs on Octopus are the same day rate as their standard variable rates (less than 30p per Kwh for me in W Yorks) and THEN you get your cheap off-peak overnight / charging rates
Its a bit more expensive in the London area. I'm also with Octopus and m yday rate is currently 45p night rate 16.3p. But this is about to come down a bit.
