No 80% charge limit
asandrews
NW Leics
MGS5
My old ZS allowed me to set the desired charge limit to 80%, 90% and 100%. I had taken to using 90%.
There doesn't seem to be any such setting on the MGS5, which is weird given the manual advises 80%.
I use IOG and with that I can specify the % additional charge so if I remember to check it and do the math I can get somewhere near, but it's an extra hassle that I am surprised they have introduced.
You can set the charge limit using the ismart app under "EV management"3rd from bottom of page.
You are of course correct, thank you.
I have also discovered that I can drag the slider between 90 and 100% on the car screen, but no lower than 90. TBH I am happy with that.
Mine allows me to slide to 80%
I will add it resisted at first, thought I could change through the numbers but ended sliding the green bar.
I'm wondering if I can't set it below 90% because the current charge level is 88%. That's a minor bug if its the case. Will see what happens in another 25 or so miles.
Why is that a bug? I'd say it's a bug if you can set the requested charge level to 80% when the current SOC is greater than 79% 🤷‍♀️
I am referring to the in-car setting. I should be able to tell it how much to charge to in the future regardless of the current charge level. Anyway it's conjecture at the moment.
I can confirm . . on the MGS5 you can only set the recharge % limit to a round number higher than the current state of charge. I'm not sure I'd call it a bug but clearly a stupid design decision. Easy work around . . wait until you are down to <30% SOC then set it and forget it
