No QR Code to Bind the phone.
If it was in someone else's name the app does not give me the opportunity to unbind it.
It's worth contacting the supplying Dealer and ask if your car is bound to one of their salespeople's phone, alternatively I'm sure there's a 'Force Unbind' option somewhere, but I can't remember where.
This is what it shows me
As per @MG Clive there should be a Force Unbind option somewhere, but I'm not sure where. If you can find it and use it, this sends a request to MG .. they then give the original account 72 hours to respond/challenge the unbind request, then do the unbind on their end (if no challenge or response).
It could be the servers are down for some reason, and it'll work again later. Or perhaps you're car is failing to connect to the servers because it's in a 4G dead spot, or parked underground or something? I think you can connect your car to your home wi-fi (or hotspot on your phone), that may be worth trying.
MG4 Long Range .. which exact model? (You've posted in the MG4 EV (2022 to 2025) Forum, so I presume yours is not a new 2026 model. As such the Long Range versions were SE LR and Trophy LR .. Trophy spec supports WiFi hotspot connection; SE doesn't).
If I sit in my car (SE SR) and press the Settings cog, scroll down to Binding and press it, then press the Bind Vehicle button I am presented with 2 buttons .. Bind Vehicle and Remove Binding. Are you saying you can't even get that far? If you can, how far can you get? (i.e. where exactly in the process is that previous photo you posted?)
Sounds like a comms problem then, as suggested earlier. It'll either sort itself out, or you'll need to get your dealer to sort it. (Might be a faulty TBox or similar - maybe even just a dislodged antenna lead).
    Votes: 1,096 77.7%
    Votes: 212 15.0%
    Votes: 103 7.3%
