Not able to put car in gear
Hanne
High Wycombe, United Kingdom
HS PHEV
When starting my MG HS PHEV 2025 model sometimes I can’t get it into gear. I have to switch off the engine and re-start for it to work. When this happens the drivers seat moves all the way into set position rather than what it is mean to do i.e. the seat immediately moves only slightly forward and then a few second after it moves into set position. I have taken it to the MG garage where I bought it but it did not happen whilst they had the car and they had not heard of this problem so could not fix it. Has anyone else had this problem?
I had this in my 2025 HS Hybrid+ a couple of times. I have had a message straighten steering wheel and another to apply brake. A think the apply brake is the most likely solution so as the car is controlled if it should jump forward or back when selecting a gear
Thank you. I have not had any messages come up when this happens, the brake is always applied when starting the car or when trying to put the car into gear, but I will double check next time it happens.
I've now tried leaving the wheels at an angle and your right this is when the car will not go into gear. My car is an automatic.
Thank you for this suggestion it seems to be the reason.
That happens when I dont fully press the Gas Pedal when pressing the start button...it dos not show "ready" in screen...I think thats a security feature so the car does not start only by pressing the start button...
