This the latest message I received from Octopus in response to messages on my phone saying "unable to control your device" :-
Please reconnect your device and remove all charging schedules and battery limits set within the vehicle infotainment system, vehicle app or charger app.
I can see that these are currently enabled either in your vehicle infotainment system, vehicle app or charger app, and as a result we are unable to properly control smart charges.
A Smart Charge will map a charge when the grid is under less strain. Most of the time this is between the set off-peak times, but this isn’t always the case. We will apply the off-peak rate to all the times we schedule your charge, regardless of when this is. This is on the condition that customers have no schedules or limiters set on the EV or charger.
Smart charges will not necessarily initiate immediately during the 11:30–05:30 off-peak window, as sometimes it can be more cost-effective to start early or delay charging until later in the night.
It’s common for a Smart Charge to start and stop multiple times throughout the night, as the charges are designed to get the most power at the most cost-effective times prior to your “ready by” time.
Our system uses constantly updated data to ensure we charge your EV to your desired SoC by the time you set. Having a Smart Charge mapped outside the off-peak times also means your entire household will receive cheaper rates during those periods.
From the information you’ve shared, cross-referenced with our data logs, there are a few settings within your vehicle’s infotainment system, app or charger app that appear to be interrupting our ability to control charging properly:
- Battery Care Mode: This needs to be disabled — it interferes with communication between the car and Octopus, and can cause the vehicle to reject our charging requests.
- Charging Limit: The vehicle appears to be set to charge to 80%, likely due to the above setting. Please change this to 100% within the vehicle and in all apps except the Octopus app.
Essentially, what’s happening is that your vehicle’s internal battery-management settings are overriding the instructions we send. Octopus can only request that the vehicle follows a plan — but in this case, the vehicle is effectively saying it already has one, so it’s rejecting ours.
Additionally, when you set your charge level in the Octopus app, it always assumes it can charge up to 100% of your battery’s total capacity. For example:
- If both your vehicle and the Octopus app are set to 80%, the actual usable charge drops to around 64% of your battery’s total capacity.
- If your vehicle, charger, and the Octopus app all have limits set to 80%, that total drops even further — to roughly 51.2% of your battery’s capacity.
This is a common factor behind the errors we’re seeing with your vehicle. The app sends a request as if it’s charging to 80%, but the vehicle perceives this as an excessive power request and cuts charging short (or stops entirely) to “protect” the battery.
Additional point of note, the Zappi integration relies on what we call relative charging. Under your charging preferences, where it says "charge to add," this specifies the amount of charge to be added on top of your current battery level.
Because of this, if the number entered results in the charger trying to add more than 100% of the battery’s capacity, it causes these errors. To avoid this, you need to set the amount to fill the empty portion of the battery. For example, if you plug in when your battery is at 25%, you’d set it to add 75% to achieve a full charge.
Typically, EV owners set their maximum state of charge to around 80% to help reduce battery degradation. So with this in mind, if you plug in at 25%, you’d set it to add 55% to reach 80%.
For Intelligent Go to function as designed, we need an uninterrupted charge or “blank page,” and the 80% battery-charge limit, as well as any charging schedules, must be set solely within the Octopus app.
Please try following the above guidance and let me know if you’re still receiving these errors afterwards.
Best wishes,
Oliver K
Smart Tariff Specialist "Pro"
I am not sure if this explanation adds anything which reduces the confusion. The big problem here is the number of different bits of digital kit (plus the EV) in my garage that all want to be in control
I have an MG4 which tells me not to charge beyond 80% to protect the battery and an energy supplier telling me to set it at 100%. That same energy supplier told me that my cheap rate for electricity would be 11.30pm to 05.30am but I now find that is not necessarily true
How are us non-geeks supposed to understand all this? Where is this advice to be found on the Octopus website or on the app? I have a garage full of digital equipment (solar PV inverter, batteries and EV charger) all from different manufacturers plus a flaky Internet connection
Throw in regular power outages during storms plus equipment software updates and you have a perfect digital storm which leads to an inconsistent service. The IOG system is designed to run without any of these interruptions so the result is a very frustrated customer
Rather like our experiences in trying find and connect to a public EV charger, trying to charge our EV at home overnight has become something of a lottery. Sometimes we get a full charge, sometimes a partial charge and sometimes no charge at all (requiring a bump charge)
Charging at a public charging point is challenging enough but I thought home charging would be simpler. How wrong I was. It seems that using IOG to charge every night, you need to check the amount of charge left in the car when you park up for the night, subtract that percentage from 80% and set the Octopus app to add that amount of charge. What a right blinking faff
We often get power outages for a few seconds during storm conditions and they cause havoc with all digital equipment. I regularly spend hours afterwards switching bits of equipment off and on trying to get them all to talk to the wi-fi router and to one another again
I have set the EV charge target in the car to 100% as Octopus recommend but I am not going to attempt to fiddle with the Zappi control panel or the myenergi app for the batteries. I am considering going back to the old (non-intelligent) Octopus Go regime
The owner of Sparky 2 is an old Analogue Man in a digital world
As Kermit once memorably said, "its not easy being green"
