Odd light on drivers display
Blacky
Rugby
I wonder if anyone can shed light on a fault i have, when driving from a standstill every time i get to 22mph a message flashes on the drivers display telling me to slow
down it is accompanied by a yellow warning light that looks like a brake with a pedal in the centre . I looked in the manual and there's no symbol that looks the same,
also the infotainment flashes a message but it is so brief i cant read it,i think it said AFV not active but i may be wrong.
Thanks in anticipation.
Paul
Is this not the message telling you that you've gone over speed for the cameras to work? I.e. If you're indicating and at standstill or moving very slowly, the 360 camera comes on in the direction you're indicating, but when you go over a certain speed it turns off and gives that warning. Sure I saw this somewhere.
" accompanied by a yellow warning light that looks like a brake with a pedal in the centre"
If I'm not mistaken is that not the hill climb auto on - 'not enabled' - I've had that loads of times - But I ignore - road is flat, just break at normal junctions and pull away - it normally goes away during drive ...
It's nothing to do with 360 camera as it was off at the time
how do you enable hill climb auto on
Was your windscreen frosty this morning? i.e. was the triangle-shaped area behind the rear-view mirror frosted over?
No frost and windows clean
Thanks for all the suggestions re light on drivers display
Got it sorted turned out to be over speed warning how I managed to set it is a mystery
    Votes: 1,092 77.8%
    Votes: 210 15.0%
    Votes: 103 7.3%
