wenkatn
- Oct 30, 2023
- Location
- Rugby, UK
- MG4 Trophy LR
I have ohme epod EVSE installed and currently with british gas electric driver v1 tariff, intending to switch to intelligent octopus go soon.
I am not sure if I quite like the ohme app or how i should be using it.
First annoyance is that you can't set the target percentage/range you want. You can only set the additional percentage/range you want it added. i understand its down to the fact that mg doesn't allow api access for the charger to check the status of the battery.
I don't charge every day. If I charge to 80% it will last a week for me before it comes down to 20-25%.
I don't have any schedules set up on ohme app. I have 80% limit set in the car. Lets say I have 40% SOC in battery. In the ohme app, I change the target to add 50% by 8am. Also in ohme app, I have set to charge only at off-peak time which is between 12 and 5am. So basically, this should start from 40% soc and adding 50% more to get 90%. Remember, in the car I have set the limit to 80%. So I expect the charging to stop once it reaches 80%. I can see the battery charging from 40% to 80% and in ismart app it keeps showing the battery charging animation even after it reached the 80%. It reached 80% around 3:30am. Even after that, ohme app wants to push the charge to the car, car showing battery charging animation, but charge not going beyond 80%. I had to manually click "Finish Charging" button in ismart app.
Should i just leave it alone, as it only charges to 80% anyway (despite the ismart graphics showing charging animation)?
Any advice appreciated. Thanks
