JodyS21
- Jan 24, 2021
- Location
- Milton Keynes
- ZS EV
I finally have my Ohme charger (with 32amp commando plug) setup.
Am trying to figure out what it's doing and why with the scheduling.
Does anyone actually know?
I wish Ohme would provide proper details on how it figures out how to calculate the charge schedule to use, plus the ZS specifics used.
Am using "ZS Exclusive (latest firmware)(2019)".
I've setup the tariff details: off peak 12:30am - 7:00am.
My car is at about 75% charged, but obviously the Ohme can't know that.
So I've just told it to add 100miles, to be finished by 6:30 and to not charge above the off-peak price. (I know it doesn't need to add that much I'm playing it safe)
Plugged it in at 4:40pm.
Attached is the charge schedule graph it's is using.
I don't really understand why it would not just start the charge at 12:30 (or 15mins after to be on safe side) when my off-peak period starts. Instead it seems to work directly backwards from the target finish time working out how long it thinks it will take and starts the charge from then i.e. around 2:30am.
This just seems frankly a silly thing to do.
For instance, what if it actually takes longer to put the specified charge into the car etc - it could be cold or something restricting what charge the car will pull, thus it risks the car not having the required state of charge when specified.
The charging schedule graph also shows that it starts to charge the car a little bit at around 1am, before actually doing the main charging a couple of hours later.
Is this to do with the ZS's 10 hours that I've read about, does the car have to be woken up within 10 hours of it being plugged in and then kept trickle charging, otherwise it cannot be woken up by the charger? I plugged it in at 4:40ish.
It looks like this is the case and, this is the work around that despite the cars firmware updates, is still necessary to do a "smart" charge.
My other concern is regarding the Ohme allowing the car to balance as necessary.
I've send Ohme a support question about this.
I don't particularly care if it does this during off-peak rate as it's not using much power, but I want the Ohme to allow the car to balance for how ever many hours it may want to after it's finished charging. Is it going to allow this i.e. let the car carry on pulling power after the scheduled end time?
I'm also wondering.
Does the Ohme stop the charge as soon as the car has taken on the amount of kWh that I effectively specify (calculated from by set range %/miles to add), or does it just go by it's calculated start/end schedule and allow the car to pull the max power for that time period it has calculated (as that should be sufficient).
I'm not convinced this super smart charger is actually going to do what is best for me (it maybe great for Octopus agile tariff)
Realistically, I just want it to allow the car to start charging as soon as my off-peak commences and allow it to fully charge followed by any necessary balancing.
Usually I'm going to need it to be fully charged by 6:30am, which will always be successfully done if it starts when my off-peak tariff commences (potentially it may not always have finished balancing by 6:30am but that's fine occasionally)
Lots to digest there, if anyone has the Ohme and real experience/knowledge of it please share it with me!
thanks Jody
I'm also wondering.
thanks Jody
