Ohme Pro and Intelligent Octopus Go.
Panther
West Midlands, UK
Not an MG
Awaiting impending delivery of MG4 and also in the process of switching to intelligent Octopus Go tariff from fixed rate.
I have an Ohme Pro charger but how do I schedule it to charge between 11.30pm and 5.30am to get the cheap 7p per Kw rate? is this done through the car, octopus app or the Ohme app or another way?
Any advice appreciated so that I'm set up to go once the car arrives.
I don't set any scheduling, car or charger, I use IOG smart charge where you just request nn% by HH time in the octopus app and let it get on with it.
You don't.
Just plug in and select how much % you want to ADD and by what time.
Ohme & Octopus decide when to charge car after you set up smart charging adding the % & time the next day you need the car.
The only catch if you have solar PV is it can consume the export. As I get 15p per unit for export vs buying at 7p off peak that is not a good idea. So I set it up & press the pause icon till sunset.
You get the 7p rate whenever IOG charges, day or night (that's the "intelligent" bit). The fixed period is just a guaranteed period of the low rate. You will often get the 7p during the day if the car is plugged in ready to charge.
Well explained, the whole house will also benefit from 7p kWh if the car charges outside of the night period
I have mine set to price cap of 7p as it might be intelligent but how do you know it won’t charge you more ?I also set mine to be off by 0530 for that reason to I do have dynamic charging on too
I’ve been on it nine months and not once had a problem with billing, initially I used to screenshot all the schedules but don’t bother anymore. It’s totally accurate. 👍
That's actually hindering you getting extra cheap charging periods that the whole house benefits.
Intelligent octopus actually tells you not to set the price cap
When it is set to dynamic charging you pay 7p whenever the car is being charged. Octopus decides that. I quite often set the "I want the car by" time to as late as possible & then we get cheap power over breakfast.
Your octopus bill will show you cost per 30 min slot per day.
I didn't think you could set a price cap on the Ohme if you are on IOG.
