One Pedal Driving, how to use?
Why wouldn't it? This isn't about imitating what ICE do, it is just about giving people choices.
Exactly. And that's why you have the choice to use OPD or not.
By the way, you don't replace two pedals with one. The brake pedal is still used when it is really needed.
I wonder if there is anyone on this forum who loves OPD and couldn't stand to buy a car without that option? The main reason I am considering replacing my Leaf with the MG4 is OPD. Without OPD, I would probably look elsewhere.
I have OPD in my 4 and have also used it in my daughters Leaf (She always uses it). Dont like it and wont be using it.
It all depends on how smooth the accelerator movement is: both the mechanical pedal and your right foot control.
I generally prefer less regen for smoother driving. Especially when using TJA: either regen 1 or adaptive.
On motorway I prefer adaptive. Makes it less stressful in controlling the accelerator.
Stiction (a made up word used by weight lifting bods) is what I am talking about: when you make a movement that requires fine adjustment but uses some force or extended control, the combination of friction and play in the mechanical machine or in this case the accelerator pedal, and your joint, in this case your ankle, cause the movement to be jerky and less controlled compared to a slightly faster movement.
Basically every single person will have a different experience
Am I correct that this is an option to turn on or not in the option of Phase 2 cars. So its not hard baked and forced to use only an option anyway?
Yes, it is an option and not the default on startup. My car always defaults to Normal mode and High Regen at startup. I don't use it on A roads / motorway driving but like it around town and local roads.
Thanks for confirming,
So its not really a discussion, of course I want it available on my car then just use it when/if you want, there's no down side.
When using it for 1st few times if it felt alien then revert back to normal. Sure it just a new mindset on changing of driving style which might be better in long run might not.
At least "Viking" agrees with me (although I don't agree with everything he says there):
In my Leaf I can easily set the level of recuperation, including "virtual" N mode (by pressing the accelerator pedal just so that there is no recuperation and no engine power).
I have the updated version with OPD. I really like it but I don't use it because it's not available all the time.....I would be afraid that I'd get used to it and possibly crash when it wasn't available. Plus the fact that you cannot save your settings is ridiculous. I've decided to use the car in default settings mode as I can't be bothered changing stuff every time I get in.
I tried the OPD and it's not for me! Set my regen to high and the car slows down great.. can't see the point of it! My brother has a Tesla and he uses one pedal all the time...
I exclusively use OPD as I find it makes driving so much more comfortable. The one thing I hate though, and honestly this is really dangerous, is that the car resets it to off for every drive. So I'll be expecting the car to come to a stop, but it keeps going. I really hope this is addressed in an update.
The brake lights do come on when you lift your foot from the accelerator.
OPD is similar, the regen is more aggressive. Another difference is that it will bring the car to a complete stop instead of a slow roll :)
I just got mine and am very confused, when it is in OPD it doesnt feel any different to the strong regen braking and does not come to a complete stop. I have to still relie on the break?
With my MG4, if the car is above 90% charge, you don't get full OPD, and will feel the same as level 3, it also takes a few seconds to come to a complete stop.
OPD is not active by default - you have to enable it every time you get in the car. Regen level 3 is the default setting.
Hmm. That must depend on the model. My XPower remembers the OPD setting. The only thing that cancels it is accidentally activating snow mode (!)
I always use it on my MG, for consistency, because my Tesla has OPD which can't be disabled.
I quite like it, actually. Once I got used to OPD I found it was easier to drive smoothly with it than by using brakes.
Unless it has been changed in the latest software variants ... received wisdom is that OPD in the MG4 (those versions that support it) defaults to Off and Regen level 3 is the default setting. Of course it could also be that your car has a foible by which it remembers something it "shouldn't". :)
I really hope my car has this 'foible' when it arrives :LOL:
Checked it specifically again today. Got in and checked the screen, OPD on. Pressed the brake pedal, OPD still on. Switched to custom mode as is my custom (ahem), OPD still on.
If yours doesn't do this, I'd better not let a dealer anywhere near it!
    Votes: 1,089 77.8%
    Votes: 209 14.9%
    Votes: 103 7.4%
