Pilot Custom
johnnyboy198427
London
MG4 EV (2026+)
Hello,
Anyone else having issues with the custom pilot button.
I am able to sucessfully save my settings, and initally the custom button works as expected. However if the car is left for a few hours, overnight for instance, the custom pilot button fails to apply the settings.
I press it, it turns blue for a few seconds, and then greys out.
Hello,
Hi you tried a reset of the infotainment system?
Hello,
There doesn't seem to be much you can set as custom on my Premium Extended Range model. Not sure if I'm doing something wrong.
Are you looking in the right place, there is a list of about 20 things you can customize under the MG Pilot tab.
Is that on the new MG4 Premium? I have a few settings I can change, not 20. Button is showing blue and seems to come up every time I start. but I still have to turn lane keeping button off every time I get in the car. Can we customise things under MG Pilot, or only what appears on the Drive button where the custom button appears?
I too am having an issue with Custom Pilot setting. I am going to see the dealer tomorrow to see if I am doing something wrong and will report back with what the dealer tells me.
I have found a little work around. While the custom button wont operate when I first get in the car. After driving, even for a few hundred metres, I can put it in park, and then press the button and the custom feature will engage. Not perfect, but an improvement.
Interesting. Thanks for sharing your work around. I will give it a go.
