JeffNaylor
Berkhamsted,UK
Hello All. newbie here
Serously considering buying an MG4 Long Range second-hand and I've looked at a few threads, but would like some advice about a few issues please
A lot of the YouTube and other reviews are very negative about the Lane detection feature being dangerous and you needing to turn it off manually, but I've also seen a comment that after a software update the feature became far less agressive. Is that the recieved wisdom now?
I saw a video about reduction gearbox oil leaks, but I'm guessing that a three year old car would have this issue fixed. Everything else seemed to be software related..
I'll probabl;y try to buy through an MG dealer. but if I can't find the car I want, would I be able to "adopt" one and get the software checked, even at a cost?
Any other things to look out for?
TIA
Jeff
LKA/LDP/ELK (pick your TLA of choice :)) is generally fine as long as the update has been done .. SC077 as I recall.
Mine had the oil leak .. it was fixed within a few months. Any car 23 plate or newer should be fine as the issue was resolved at the factory; most 72 plate cars will have had the fix anyway.
When buying 2nd hand, make sure it has a full (and up to date) service history with MG, to ensure that the warranty is intact.
Given the issues I have had for 6 months with my ZS EV, I have been driving an MG4 loan car for the last 9 weeks whilst the ZS sits at an MG dealer. EMG in Ipswich.
I won't be buying another MG & suggest you think very carefully as the MG UK CS support is below poor. My fault started in an 11 month old car & no one knows how to fix it. The wrong spares have been supplied etc . The dealer blames MG UK. MG UK blames the dealer.
The lane control on the 4 I find annoying as is the speed limit bong. You can turn them off but the next time you start the car they are back.
The car is a 74 plate dealer courtesy car.
@JeffNaylor, siteguru has given you the basics on mechanical issue and service campaigns.
Warranty can be an issue, it has to be serviced, and electronically documented on line by MG on a dealer portal. It seems that only MG can access these records and verify these services have been carried out, otherwise any claims may not be accepted. So paperwork of proof of services is essential from a dealer.
SE and Trophy trims were available in LR and eventually an ER version for the Trophy as well.
Go through the specs, and decide what you'll go for. Upgrading from SE to Trophy specs isn't a thing that can be done.
The Trophy had many extra items over the SE, like built in Sat Nav, birds eye camera system, enhanced radar/ ultrasound systems for parking and rear collision etc, heated front seats, electrically adjustable drivers seat, on line services, and an enhanced 6 speaker audio system.
To the forum, Jeff. You'll get all sorts of different opinions on this. Those with bad experiences will say, don't get one. Those with good experiences will obviously say get one. I'm in the get one camp.
It's up to you. Good luck. 🙂👍
this ^^^. But also check it out and get it in writing. Too many stories on here of MG sales staff saying it has a full warranty then new owner finding out that was a lie. I had similar experience from same dealership that @JohnV6 is having warranty issues with, so didn't go ahead with purchase.
EVs are great things and my ZS was a great car, but just be aware MG support for problems is weak, slow and disinterested I suspect and know other brands are more customer focused.
    Votes: 1,096 77.7%
    Votes: 212 15.0%
    Votes: 103 7.3%
