IanMG
Mine says 'Battery Pack Heating Failure'!
A trip to the dealer?
Mine tooMine says 'Battery Pack Heating Failure'!
Ah, that’s interesting! I might try it tomorrow.Ahha! I THINK I have the answer!! After repeated attempts to engage the Battery Heater, I have found that the error message: ‘Battery Pack Heating Failure’ is displayed when the Car Charging timer is active. Switch off the Car Charger Timer and hey presto…… well it works for me anyway! Hoping you all meet with similar success.
Which app do you get these values with?So a bit more testing on way home -5 40 mins battery heater on so probably take a whole hour for sweet spot?
I am very confused.I have the new version 1.1.8 on Android. I used the preheating a while this morning. It used about 6kw for 15 min, but I didn't notice any decreased consumption when driving 200km afterwards (-2°C). The average was 2,1kw/100km. Mostly 110km/h.
By the way - no errors.
The trip meter shows kWh/10km. Now in winter I'm getting 1.7kwh for slower driving and 2.2 at 110km/h. More for really short trips. Normal and expected. If I remember, the preheating was 6kw and not 6kwh. It was probably doing more than just heating the battery. I think others with better knowledge have found out the battery heater is using 3kw.Which app do you get these values with?
I am very confused.
How do you know the 6kW?
Mine needs 22kWh/100km at these temperatures. You only 2.1?!?
Do you always mean kWh? This is a unit of energy.
kW is a unit of power. At 6 kWh in 15 minutes, that would be a power of 24kW. That would be huge!
It has been suggested that it used double that figure a greedy beast alright .I think others with better knowledge have found out the battery heater is using 3kw.
Just a quick battery heater test to see how much power it uses the heater it's self is a 3kw water heater View attachment 13898
Car in ready mode uses about 0.3kw when lights are on but cabin heater is off when battery heater is on you have 3kw after start up and about 0.3 kw for the water pump here is a very quick video showing power used a you can see the HV battery coolant warming
The app is eZS - Apps on Google Play@N2STY Which app do you get these values with?
