lmjg4t
- Nov 1, 2024
- preston, uk
- MG4 (2022-2025)
I’ve watched many YouTube videos and read this forum but still have some questions/issues (picking up the car today trophy LR):
-has there been an update to now allow the car to pre heat the cabin whilst being plugged in but after charging?
-how do you ensure that the car uses power from the charger when pre heating the cabin and/or the battery when it’s plugged in?
-planning on using the hypervolt app to deal with all the charging schedule - car needs to finish charging at 5am to maximise the cheap overnight rate I’ll be getting. Can I use the hypervolt app to deal with charging finishing at 5, and then flick the cabin pre heat on at 5:50 ready to leave at 6 and this power be drawn from the charger still when the charging schedule is finished? Or do I need to allow the schedule to finish at 6 instead?
-will probably use the pre heat battery function in the winter when it’s sub zero, the same question applies there, I want to use the hypervolt app to run the charge, but ideally the vehicle to pull power from the charger still for this outside of the chargers schedule.
From what I’ve read on here there is no way to defrost the rear window and wing mirrors from the app?
Do you have to use HVAC when preheating cabin?
Does the vehicle remember how you set the blowers for the defrost? Or should you manually close the flaps?
TIA!
TIA!
