Just a note about battery voltage. Unless the car is at 100% state of charge with no load on at all they are meaningless. The only figures you can use to compare are when it is at 100%.
The difference is the top bufferStrange as the car has finished charging and had also equalised so not sure why its showing 93%
This ties in with what the OVMS guys were thinking plus what @MilesperkWh also said a while back.The difference is the top buffer
So it's normal, nothing to worry about if 93-4% on the new update. Prior to that about 96-7%
The green and white one on amazon has gone back down in price so have ordered it.Theres lots around like this....
Someone reported success and posted their readings with it.
As I mentioned above the data is pretty meaningless if you are not at 100% SoC as that is the only figure we can use to compare.First reading and OBDII device used; will upload data with 100% charge later in the week. Bought car end of December 2020, driven 500 miles, never used rapid charger, only used fast 7 KWH charger. BMS update on 25/01/2021.Done only one equalisation since, got 449V. How data compare with other cars of the similar age and mileage?
Thanks Mike, will come back with figures with 100% SoC.As I mentioned above the data is pretty meaningless if you are not at 100% SoC as that is the only figure we can use to compare.
Originally we were all focused on identifying the software versions, which is the data we were collecting.As I mentioned above the data is pretty meaningless if you are not at 100% SoC as that is the only figure we can use to compare.
Added to the spreadsheet thanks.First reading and OBDII device used; will upload data with 100% charge later in the week. Bought car end of December 2020, driven 500 miles, never used rapid charger, only used fast 7 KWH charger. BMS update on 25/01/2021.Done only one equalisation since, got 449V. How data compare with other cars of the similar age and mileage?
I wonder if the way the charging works is that it charges to X (Voltage or SoC%) amount (a nice round 93%), Then it does balancing to what ever that ends up producing.Car was returned on Thursday after 2 weeks at the dealer in Norway, the updated BMS software was installed and then they carried out balancing. As you see in the screenshot voltage is now 449.
On eco I am seeing max range with heating "Off" of 284km (178 miles). I charged to 100% and it balanced for 4 hours with a draw of 0.3kW. After showing 100% and charging complete it added 1kW which is much less than before the update, where I saw 2.2kW added when balancing.
This is the screen displayed in the ZS EV app that show the Battery Voltage and SOC% and confirms there is approx. 6% that is being held back as a top and bottom buffer. After the car displayed Charging Complete and 100% SOC the app showed an SOC of 93% After balancing this increased to 93.8% (as shown below), but the estimated range didn't change. After the latest updates I have noticed there is regen even if the SOC shows 100%. When the car was collected they told me the imbalance was 23mv. So will be interesting to see if this goes down after more charging sessions. The BMS version that is being displayed in the app is 0210622EU1
Hope this helps us get a better understanding of effect of the latest BMS update.
Oh darn, that blows the A-C HVAC with the excite/exclusive idea out the windowMy device arrived a few minutes ago.
Read the firmware.
Currently have around 50% charge which is consistent with the GOM and the bar display.
Car (excite) registered August 2020. Has 15 jan BMS but had the duff one for a few weeks.
Oh no you're right!Oh darn, that blows the A-C HVAC with the excite/exclusive idea out the window
