Radio module replacement
Have sent you a DM
Hi there, I have an MG ZS and have had the same issue where by the radio FM, AM or DAB it always displays the Radio Initializing. I have spent many weeks and hours scrolling around the internet until I came across this thread. If you are still active would it be possible I you could send me the DAB files please so I could update my DAB file. Ive read on the internet about disconnecting the battery, forcing a hard reset also doing a factory reset and none of that worked. My next option was to book in at the dealer but if im honest im a bit reluctant to. I to tried to update the DAB through the engineering screen thinking that would update the DAB station list but as soon as that fail and i went back to the normal operating screen I saw that all radio stations were lost. If you could send me those files I would be so grateful!
Apologies, I have successfully download the files. I was unaware the the files were available to be downloaded.
If the update does not help, disable DAB/RDS in the engineering settings - page 3.
FM/AM radio without RDS should start up.
This was the case in my MG EHS before the RBRM module was fitted.
Thank you! I will give that a try when I get home. Appreciate the advice, if it works or doesn't work I will let know.
