Rear View Mirror Removal
Joe MG5
Malvern
Does anyone know how to remove a rear view mirror for a mg5? I'd like to replace mine with one higher up and less broad. Many thanks.
Hi, is it the MG5 SR that you have? It should be just stuck on.
Thanks for the replies. It is a 2021 Mg5 Exclusive EV. I'm not very interested in the auto dimming, and would rather have a less obstructed view.
Part of your problem is that behind the mirror is a ***king great box that houses the rain sensors and blocks just as much of your view as the mirror does. I have the same problem and hate having to bend down and peer under it every time I want to turn left.
Agreed 100%. I've not measured it exactly but suspect that the positioning of this is designed for LHD. I'm also definitely not as good as getting lined up properly when reverse parking in the MG5 than I used to be and I don't think it's just age...
There is something odd about the MG5, I always had problems getting the damn thing straight when reversing into a car park bay. Whenever I thought it was straight it was way off.
Agreed.
I had to reverse about a quarter of a mile down a country lane last summer and I had to keep straightening back up because I was veering off all the time when I thought I was going straight.
The reverse camera puts me off when parking as the lines are so far off straight. Have to try and ignore it while doing my checks
Hi
The shroud around the mirror is in two halves left and right
Just feel around the edges and you will feel the clips holding it to the windscreen
Just unclip those then unclip the two halves
The mirror is held on by one screw an then just unclip the wires
I did this in the first month
I’ve attached a rear view mirror from a Fiesta to the top of the shroud near the headlining
