A working DC/DC powers all low voltage circuits (including the 12V aux). Because the DC voltage is higher (around 14V) than the aux battery’s (12ish) current will flow into it (aka charging).
If this were the case what purpose does the 12V aux serve other than starting the car ?
From the interweb conflicting versions:
In an electric vehicle (EV), accessories like lights and windscreen wipers are powered by a standard
12V auxiliary battery, similar to those found in petrol and diesel powered cars.
The electrical architecture of an EV typically consists of two main systems:
- Low-Voltage (12V) System:This powers all standard "accessory" systems, including:
- Exterior and interior lights.
- Windscreen wipers and washer fluid pumps.
- Infotainment screens, dashboard displays, and sound systems.
- Safety features like airbags, central locking, and security alarms.
- Onboard computers that "wake up" the vehicle and manage the high-voltage system.
- High-Voltage System: This primary battery pack (typically 400V to 800V) is dedicated almost exclusively to the powertrain (driving the motor) and climate control systems like the AC compressor.
How the 12V Battery is Charged
Unlike traditional cars that use an alternator driven by an engine, EVs use a
DC-to-DC converter. This device takes high-voltage electricity from the main traction battery and "steps it down" to roughly 12–14 volts to keep the auxiliary battery charged while the vehicle is running or plugged in.
the interweb also says the function of the DC to DC converter is
Key Functions:
- Voltage Step-Down: Converts high-voltage DC (HVDC) from the main battery pack into low-voltage DC (LVDC) for the vehicle's subsystems.
- Powering Accessories: Supplies power for headlights, wipers, infotainment screens, sensors, fans, pumps, and other standard car parts.
- Charging the 12V Battery: Keeps the smaller 12V battery topped up, which is essential for starting the car and running safety features when the high-voltage system is off.
- System Management: Manages energy flow and can perform pre-charging and active discharging functions for other high-voltage components, ensuring safe power-up and shutdown.
Just goes to show you can't rely on the all knowing and artificial definitely not intelligence of the interweb.
Personally I'm going for option 1 above as it seems to be too complicated to have 2 power sources for the cars accessories rather than the traditional one of charge the 12V, by either alternator or DC/DC and then let that do the work..
