RoadUser
In the last few days I've noticed the regen doesn't seem as strong as it used to, while according to the dash it's regen'ing (the needle goes to the charge bit around as before and Amp numbers are in the negative) but the car doesn't seem to slow down as it used to before. I usually drive in normal mode, kers 2. This is both when the temp has been around 10c and also same with 5c, as I understand generally the temp can have an effect on regen.
In the regen braking process, what actually slows down the car?
