I will check tomorrow and get back to you.
As promised @Mgzs ev I have removed one of the plastic scuttle retaining clips for you to see.
It’s a two piece affair, the centre piece with the cross head is false.
It has no threads as such !.
You need to use a plastic trim removal tool or use a couple of very small electrical screw drivers.
You need to get under the edges of what looks like the screw section, and pry up.
This will lift out the centre of the retaining clip.
This leaves the outer section of the hold down fixing.
Repeat the same process on the lower part of the clip with a trim tool or the small screwdrivers ?.
I will include a photo of the clip in its two parts.
When you are refitting the clips, push in the outer section first, then just push in the part that looks like a screw.
This will spread open the jaws of the lower section.
I had to remove a second clip assembly as I dropped the first one on the drive.
I am buggered if I can find it ?.
