Rodents ate my car (well not quite but they had a go)
Kentboy
Wherever
You know your vehicle has a pest problem when you're doing 60 down the motorway and a mouse appears from under the bonnet, sits on the wipers and stares at you through the glass. Turns out the thing had made its home in the pollen filter and done a fair bit of nibbling too.
I pick up my new MG4 this week and I'd like it not to be a mouse home. As well as much eradicating around the garage I'm thinking of installing this.
HONGXIAN Car Vehicle Ultrasonic Mouse Repeller,Under Hood Animal Repeller,Rat Rodent Pest Animal Deterrent,battery operated Mice Repeller, Rodent Scare for indoor, outdoor and garden : Amazon.co.uk: Garden
I've had lots of success with sonar pest repellent devices elsewhere (including against the dreaded rabbits). The question I ask the hive mind here is... does it sound a good idea? The load must be very low since it can also run off three rechargeable AAs. It comes with cables to attach it to the 12 volt battery though. And I would need to work out a way of fixing it inside the bonnet to stop it rolling around. I don't imagine there's a USB socket under the bonnet which would be one way of powering it too.
All advice welcome. And to answer the inevitable question - did I flip the wipers to get rid of them mouse on the motorway? No. Like an idiot I waited till I got home and flew out of the car intending to shoo the thing away.
It ran back down into the bonnet before I could get there.
Rodent damage to the electrical wiring system will be absolutely catastrophic, you need a fix quickly as this will not be covered under warranty, as I am sure you know.
A close friend had a brand new VW delivered and three days later, it would not start.
The recovery people were called and they found that squirrels ?️ had eaten through some of the electrical cables under the bonnet.
It is similar situation if they invalid the loft of your house etc.
Apparently, when the insolation for the cables are produced they add vegetable oil in the plastic making process, when installed the rodents can smell this oil in the protective sheathing of the cable and therefore chew and snack on it !.
Cabin filters make brilliant nests for mice etc.
Try and locate the inlet duct for the HVAC system and maybe consider fitting some type of fine gauge mesh over the intake to prevent them getting into the cabin.
This is what they can do picture below is of my sons Tesla Model X middle of last year car was parked back of the river at the 02 arena in London where he works he said when he turn on the car it lit up like a Christmas tree and he took ont the frunk under the bonnet to get at the 12 volt battery and found this mess.Rats
Les
This happened to my Mother’s Peugeot, costing around £350 in repairs. She now uses one of these devices Isotronic, which seems to do the trick. Fortunately, there are cats galore on our estate.
Have something similar on order plus a repeller for the car port. Fingers crossed.
Les
Boy that's grim. There should be an option for sonic repellents from the manufacturer
Found a little foxxer has chewed through the trim piece between the bonnet and windshield, no other signs of animals and perhaps it was prior and I just noticded now.
Have emailed MG for the part as typically can't find it anywhere.
Why didn't you put the wipers on. It would've been a Flying Mouse. 🤨🐀
You could put speakers under the bonnet and play Barry Manilow songs on continuous loop, or Bob Dylan .... but that might end bad with animal rights getting onto you for being even crueller than a cat ...... Or maybe old tapes of the BBC news readers, and send them into a coma .......... Actually, you could run a few You Tube episodes of EV Werks, if they can stay awake through that they must have a source of neat caffeine some where
T1 Terry
The PVC coating in electrical wiring in Europe is impregnated with anti rodent chemicals ? ( foul tasting ) whether or not China and the USA have the same standards is unclear.
I reckon they might do as the little buggers have chewed at the top of the jump pack that I keep under the bonnet, but on inspection all the wiring seems fine.
    Votes: 1,052 77.9%
    Votes: 204 15.1%
