Scheduled Granny Charging
GreenZebra
Sussex
Hi I have just bought a used Zs 2019 model and wondered is it possible with the factory provided MG 3-pin granny charger to schedule the car to charge at certain times? Whether through there iSmart app or within the car? Or do I need to buy a cable that has this function included?
Hi I have just bought a used Zs 2019 model and wondered is it possible with the factory provided MG 3-pin granny charger to schedule the car to charge at certain times? Whether through there iSmart app or within the car? Or do I need to buy a cable that what has this function included?
If you have an overnight tariff then it works better wilth a 7kW EVSE.
Check out the Ohme or Zappi.
None of those apply to the gen 1 & granny charger.
Use a wall socket timer, eg:
There is disagreement on this forum about the damage that may or may not occur from mechanically switching the AC input to the car, e.g. by using an AC timer.
I maintain that disconnecting an inductive load like the on-board charger under load (when charging) produces inductive kick-back that is dangerous to the switch or relay contacts and far more importantly to the expensive on-board charger. This damage may take a year to result in failure.
I've seen the arc that results from unplugging a charger under load. This was an EV conversion, not a production EV, but I believe that the same thing applies.
Others maintain that there is no damage.
Well put. The pilot signal is there for a reason.
