Are you able to set it to 80% in the car?MGZs 2023 trophy
Have downloaded ismart to my Samsung s24 ultra all works except unable to set charging other than scheduled would like to be able to set 80% charge, anyone any ideas?
TIA
As yet have not tried only had vehicle 2 weeks and it's takin me ages to get used to everythingAre you able to set it to 80% in the car?
Also with Octopus but only octopus go as octopus doesn't support my Rolec QuBev charger I use the Qub app to set the scheduleOut of interest, who is your electricity supplier?
I have had my ZS Standard Range for 3 years now and I always charge to 100% (I do about 120-150 miles a day as my office is a 100 mile round trip away).
I am with Octopus Energy and use the Intelligent Octopus Go tariff which gives cheap charging overnight. I have an Ohme Pro charger.
I don't touch the iSmart app or the car's system to mess with the charging settings. I only use the Ohme app to set how much I want to top up the car with. It has never failed and uses the cheaper time for charging, usually 2330-0530hrs.
HTH
Andrew
I guess I have the 50 kw as I only have the latter 2 optionsIn the app, if your car supports it, you go to the tab where you can see charging status and battery status, press the "diamond" in the top right corner and there is the options for charge %, timed charging and timed battery heating
If you have the one with the 50KW batteri, i suspect you will only have the 2 latter options
I have nearly the same setup, except a Zappi charger. I never touch the MG charge settings or the Zappi settings, I just use the Intelligent Octopus Go app. Using this, you just set the charge you want to add and the time you want it ready by. You're then not restricted to the 2330-0530 time slot, Octopus will do the scheduling for you and can be any time, eg a couple of days ago it started charging from 2130-2200, 2230-0100, 0200-0400 and 0600-0800. When they schedule it you always only get charged 7p for the energy whatever time it is. A couple of times I've come down in the morning at 0730 and remembered I hadn't charged but needed to go somewhere in the afternoon, so set the parameters to add 50% and be ready for 1100 (the latest you can set) so it created a schedule, started charging straight away and so I topped up with 3.5hrs of charge, at 7p rate.Out of interest, who is your electricity supplier?
HTH
Andrew
Standard range models are designed to charge the traction batteryI guess I have the 50 kw as I only have the latter 2 options
The 50 is the standard range so yeah standard range = LFP battery = Can be charged to 100% every time without problemAs yet have not tried only had vehicle 2 weeks and it's takin me ages to get used to everything
No, apparently standard just charges to 100%Are you able to set it to 80% in the car?
