yonchevsv
- Jan 6, 2026
- Prescot
- MG4 (2022-2025)
If you’re tired of the constant beeping and want a quick way to disable the chime without affecting the seatbelt's physical operation, follow these steps. The seatbelt itself continues to work perfectly fine; this only stops the electronic sensor from triggering the alarm.
Steps to follow:
• Remove the seat: easy, just lift it up
• Identify the plugs: Locate the wiring connectors on both the left and right sides.
• Disconnect: Unplug the occupancy sensor connectors. This stops the car from "sensing" weight on the seat and eliminates the chime.
I have attached photos below to show the exact plugs you need to disconnect.
Steps to follow:
