- Sep 3, 2022
- Solutions
- 3
- Location
- Strathaven (SE SR MY22)
- MG4
SCUK001 was the only update reference given to me when mine was updated and the ACC change had been applied. ?
Are you sure? There's no way for module versions to be interrogated?Part of the problem is that the dealer can't check - they depend on the update process working correctly but it is not always reliable and there's no way for them to independently check the versions.
Yes, sadly, I have had it confirmed and Miles has also spoken about this. They only know what you have when they plug your car in for updates.Are you sure? There's no way for module versions to be interrogated?
Then again, from what we've learnt over the past 2 years...
There is the eZS app, Android only, and designed for the ZS models. But it can probably tell you at least some of the module firmware version numbers.There's no way for module versions to be interrogated?
UPDATE: They updated the FICM, CCU, BMS, and IMCU and checked all the other software. They even checked the brakes and discs, tyre wear etc. They also checked if the car stopped at 80% charge, which it did, so I got 20% battery charge for free. And yes I'm now on the fabled R59 infotainment software.I've taken my car in again this morning for the software to be corrected after the last time when the update stopped the car being able to stop at 80% charge and the range appeared to be reduced to the SR level.
I've also asked them again to update the infotainment software as it keeps dropping the Bluetooth connection and I get a black screen when the auto lights come on during boot-up. I was still on R24.
Call me cynical but I have suspected in the past they've only done the minimum updates necessary if at all. This morning it seems my suspicions were correct as for the first time I've received warning messages in the iSmart app for power steering, brake system, tyre pressures, airbag and power steering again.
Just had mine updated to R59 and got them to plug the laptop in and update everything required (they also informed me that there was a recall update?). It is the updated 18" wheel Trophy LR. Car is behaving better than before (my LKA has never really been a problem) and also can confirm that the car appears noticibly quicker in normal setting and seems to drive even better. It is good to have the quick option to turn off LKA (I drive different types of road). The updates were carried out as part of the 1st service, but I had to complain about iffy LKA and freezing screen for them to update to R59. They did have a few problems with the updates and kept the car overnight, I had a loan car so no problemsUPDATE: They updated the FICM, CCU, BMS, and IMCU and checked all the other software. They even checked the brakes and discs, tyre wear etc. They also checked if the car stopped at 80% charge, which it did, so I got 20% battery charge for free. And yes I'm now on the fabled R59 infotainment software.
I also left a concise polite note on the passenger seat for the technician of the faults and when they occurred which probably helped.
It might be my imagination but the car now seems quicker, but that could be a result of having a manual Fiat 500 hybrid as the courtesy car ?
Great to hear you've had yours all fixed and tidied up, nice one!UPDATE: They updated the FICM, CCU, BMS, and IMCU and checked all the other software. They even checked the brakes and discs, tyre wear etc. They also checked if the car stopped at 80% charge, which it did, so I got 20% battery charge for free. And yes I'm now on the fabled R59 infotainment software.
I did it because I noticed previously that the usually young person on reception doesn't know what you are talking about and writes down a shortened version of their interpretation of the fault.Great to hear you've had yours all fixed and tidied up, nice one!
I like your idea of leaving a note on the seat, I think I'll do the same when mine goes in for a service so I know they don't miss anything.
To get the infotainment software updated complain that the DAB radio keeps dropping out and the Bluetooth looses connection. If there's no fault MG won't pay for the dealer's time.I will have to remember that as well and leave a note... just booked mine in for 19th August. Got the car a week or so ago, and happy, but there are some issues with the software (R30, Trophy LR). The iSmart app won't bind even though they've supposedly unbound it from previous owner, the radio and satnav simply froze on a longer journey at the weekend, and wouldn't come back until I powered off the car and back on again (I've since found you can restart the unit by holding the home button).
Also LKA is very "grabby" - I'm not sure if they'll apply any update for that, but it was quite disconcerting on one of our narrower windy A roads the other day, when it pulled towards the centre line just as a fire engine was passing the other way!
Yeah - I have a few issues:To get the infotainment software updated complain that the DAB radio keeps dropping out and the Bluetooth looses connection. If there's no fault MG won't pay for the dealer's time.
It's been mentioned in the recent podcast and elsewhere that there is an update in the pipeline for the LKA and that owners will be recieving a letter from their dealrs about this.
If you've got the latest version of the iSmart app you should be able to request that the car be unbound.
