Fluffykins
- Dec 23, 2020
- Norfolk (my lovely)
- MGS6
Watch out if you use any kind of granny charger outside. They ain't necessarily waterproof!
I've just completed a V2L adaptor for my MGS6, using bits cannibalised from a non-working, Cord branded granny charger from eBay. (470ohm PE to PP, PE to CP open circuit, fyi.)
Taking the donor granny apart to disconnect the leads, I discovered the guts to be coated in water. Despite being labelled IP65, it doesn't seem that resistant
There were no puddles but it was thoroughly wetted; loads of corrosion - and the LCD display polariser falling off. No way would I dry that out and trust it.
I think the takeaway is beware with all grannies.
I've been using an Electraline 300180 (X-Large size) to store my own granny in and also to protect the charger if I have to use it outside (camping trips etc).
Lidl did offer these for a time but I've not seen them there for a while.
Enjoy.
Electraline 300180 Waterproof Protective Box for Outdoor Electrical Connections Weatherproof IP54 with 5 Cable Outlets (from 7.5 mm to 12.4 mm), Dimensions 390 x 228 x 138 mm, Green, Empty X-Large : Amazon.co.uk: DIY & Tools
Free delivery and returns on all eligible orders. Shop Electraline 300180 Waterproof Protective Box for Outdoor Electrical Connections Weatherproof IP54 with 5 Cable Outlets (from 7.5 mm to 12.4 mm), Dimensions 390 x 228 x 138 mm, Green, Empty X-Large.
www.amazon.co.uk
Enjoy.
