I could swear mine balanced at around 250W not 2.5kW, for between 1-2 hours.
I'll check again next time I charge it.
Yeah - From memory, when I had the OEM software, my balance time was around the 1 hour mark.
But I have to admit, I only fully charged when I had a long journey to make.
Otherwise, I would only charge to a level that I needed, with a little bit more of a buffer, just in case.
If I had about 80 - 100 miles of range on the GOM, this would take care of most of our local stuff, and a bit to spare.
I do more charging and balancing now after the BMS update.
But never every time I charge, that’s for sure !.
The pack displays a regular 448 volts when I fully charge, that’s good enough for me.
It has hit 449 and even 450 on two occasions, very briefly.
The predicted mileage after a full charge varies a little, but that does not concern me too greatly to be totally honest.
The car has covered 13,000 miles now and I guess it has a little degradation, given all the software updates etc it has gone through.
I have no idea on the current SOH of the pack, but it again this does not overly concern me either.
It runs and performs just fine and therefore you have to be happy with that I guess !.
Charging & balancing on a constant basis, chasing the magical unicorn figures is not really what I want to be doing personally.
The car has only been on a rapid about three times in 18 months, and they where just a quick “Splash & Dash” .
The bill for my last rapid arrived yesterday, it was for £1.32.
This gives you an example of how little my rapid charging has been over this time.
I would say that 99.9% of our charging needs, are done from on our drive, on the cheaper off peak rate.
My feet are completely and firmly planted in the “If the car is running, charging and performing okay ( range etc ) then leave it WELL alone”.
Intervention by the dealer is on the similar level as conducting surgery in my book, it should only be the considered as the very last resort
It’s a common know fact that Lithium batteries degrade quickly straight from the “Get Go” then this slows down again to a more stable level really quickly.
Manufactures know this and this margin COULD therefore be built into the values reported by the battery.
Giving the manufacture a bigger head room in the pack to avoid any customer concerns as there predicted range is decreasing in the cars early life.
I affect, the car reports 100% full charged when the pack is new and then when that initial degradation sets in, the car is still set up to report 100% after a charge and therefore the owner is happy about the SOH of his battery, because it still reports 100%.
Well that’s my theory anyway
