SSEN main rating fuse wont help
These are the pictures I submitted to the Wallbox installer
Old is prior to the upgrades, the switch box on the right is required as the house consumer unit is more than 5m (run length) away from the meter. New has the new consumer unit on the left, the Henley block (brown box just below the meter) splits the meter tails to the two consumer units and the new control box to the right of the meter with the new earth in between.
The Wallbox is essentially on the outside of wall behind the switch box so about a meter away from the dedicated CU.
Sorry, Site having problems uploading files?
That's the finished job it's used to be a loop supply
The missing cable used to supply my neighbour and they got given a new supply
All work was free with ovo and UK power networks ?
